Results 1 to 2 of 2
Thread: Structural Framing Family not behaving
    August 7, 2017
    1
    04:33 AM
    Exclamation Structural Framing Family not behaving
    Hi all. i have a structural framing beam which i have created using 2 different profiles and then have been sweeped (because i prefer how they behave as to extrusions). the family itself flexes fine using the parameters within the profiles loaded. however, i can not in the world manage to get the centre line of the beam to be correct.
    as i have created a family catalogue the centre line changes on all beams, and the shape handle is 20mm off the bottom? anyone know how they can be restored to the centre?
    when i pull the component end the family stretches fine, however, when i pull the shape handles the beam remain the same size, however, the "start extrusion & End extrusion date in the properties bar change to what the shape handles have been stretched to.
    Please help. thank you
    Attached Thumbnails Attached Thumbnails Structural Framing Family not behaving-sfs-beam-issue.png
    Senior Member
    December 16, 2010
    856
    01:33 PM
    I dont have access to your family, however try this first
    If I understand correctly, the centre line is not adjusting length to the newly set length of the family?
    In your family editor - Click on the "align" button and align to the left and right constraints of your object the ENDPOINT of the centreline symbolic line and lock it to the extents.
    Try this out see if it solves your problem.
    If your centreline is not staying in the centre of your beam if the width changes, add a continuous dimension that goes from top to center to bottom click on the "EQ" text on the dimension string and this should fix that issue.
  1. analytical model in a structural framing family
    By valia in forum Structure - Family Creation
    Last Post: June 30th, 2017, 06:26 AM
  2. Nested Connection in Structural Framing Family RVT 2016
    By DDennehy in forum Structure - Family Creation
    Last Post: January 5th, 2017, 02:45 PM
  3. Structural Framing Based Family
    By navidhedayati in forum Structure - Family Creation
    Last Post: August 17th, 2016, 04:32 PM
  4. Constrain structural framing to r.p. intersection in family
    By byk3bep in forum Architecture and General Revit Questions
    Last Post: March 5th, 2015, 03:04 PM
