Results 1 to 4 of 4
Thread: analytical model in a structural framing family
    June 13, 2017
    2
    04:50 PM
    Hello!
    I' m a graduate student of civil engineering and new to Revit!
    I have created a face-based family and set the family category to "structural framing". It seems to work fine as far as the structural material and rebars are concerned... But I have a problem with the analytical model of the family. I cannot activate the analytical model option and I do not know how to create analytical surfaces that fit to the shape of the created object.
    Is there someone that has been facing a similar problem?
    Can we define an analytical model of our choice within a family?
    How do we export a custom loaded family to sofistik?
    Thank very much in advance
    September 8, 2014
    India
    59
    11:20 PM
    no need to worry about analytical line. it will be created automatically based on category of Structural framing.
    Analytical line is based on the bounding Box.
    June 13, 2017
    2
    04:50 PM
    Thank you very much for your answer... My goal is to create a tunnel junction and export it into sofistik... So, in the beginning a created a generic model face based family (in order to cut and reshape automatically the "hosting" wall) and then changed the category to Structural Framing.. when I export the model in Sofistik the void in the hosting wall is created but the analytical model of the new family is not there... In Revit I cannot see the analytical model option activated... I have the possibility to attach a structural material to the object and create its rebars though (so it works indeed as a structural object)...
    I had never before read about this bounding box... I am searching about it and I hope it will get me somewhere..
    Unfortunately though, the analytical model is not automatically created in my case... and I am searching for a hint for such cases... It would be really helpful... Have you ever faced a similar problem or heard anything similar?
    September 8, 2014
    India
    59
    11:20 PM
    Sorry for very late reply, many new jonnies to Revit are facing this issue. Bounding box is nothing but the outer edges of the family element.
    Ex 300x300 Column , here the bounding box is 300x300. The analytical line is always at the centroid. it will automatically change in project depends on site condition. where the other element node is present with in the bounding box.
    Thank you
  1. Structural Framing Based Family
    By navidhedayati in forum Structure - Family Creation
    Last Post: August 17th, 2016, 04:32 PM
  2. Replies: 0
    Last Post: May 2nd, 2015, 01:18 AM
  3. Constrain structural framing to r.p. intersection in family
    By byk3bep in forum Architecture and General Revit Questions
    Last Post: March 5th, 2015, 04:04 PM
  4. How to add Analytical Model to Adaptive Family?
    By Davide in forum Structure - Family Creation
    Last Post: February 11th, 2013, 09:18 PM
  5. Generic model and structural framing beam and braces familes
    By simon1688 in forum Architecture - Family Creation
    Last Post: March 31st, 2012, 10:26 PM
