Results 1 to 6 of 6
Thread: How to make analytical model of specialized column
    May 22, 2017
    3
    04:24 PM
    Exclamation How to make analytical model of specialized column
    Hi guys i have created the above column using structural column tamplete but i am unable to create analytical column of of similar geometry the analytical that come along with this is a straight vertical line, please help i have intermediate knowledge of revit
    Attached Thumbnails Attached Thumbnails How to make analytical model of specialized column-steel-column.png
    May 22, 2017
    3
    04:24 PM
    Please guys help me
    Member HansLammerts's Avatar
    April 22, 2011
    441
    10:24 AM
    It isn't that hard to determine the analytical lines x,z of this. Sorry if being straightforward here.. Are you a student? What (3d?) software are you using to do structural tasks? I noticed some funny looking k/s on the right (...?? Wondering why you think it is 'Revit question' to be solved)
    May 22, 2017
    3
    04:24 PM
    Quote Originally Posted by HansLammerts View Post
    I Will use robot structure for structural analysis I have created this column using structural column family tamplete but it doest not make analytical model similar to the geometry, there should be a vertical analytical line following two branched model lines making a "Y". Instead there is only one vertical line.
    Attached Thumbnails Attached Thumbnails How to make analytical model of specialized column-truss.png
    April 22, 2011
    441
    10:24 AM
    I don't think in ONE column the analytical lines can split into two branches. Is it modelled as one piece? My advice would be to consider two seperate models, one for arch, one for Robot use with simplified element, and correct analytical lines. Its hard to have them both in onebim.
    September 8, 2014
    India
    59
    04:54 PM
    Analytical Line cant able to Draw manually.
    it will be single Line based on Bounding Box.
    If you want Y Shape Analytical Line you need to Create the column in 3 Parts.
  1. How to adjust analytical model and nodes with physical model
    By saif abedin in forum Structure - General Questions
    Last Post: August 28th, 2016, 05:11 PM
  2. Analytical model of a model in-place
    By pttpx2 in forum Architecture and General Revit Questions
    Last Post: June 14th, 2016, 09:59 PM
  3. Analytical column
    By sink69 in forum Structure - Family Creation
    Last Post: April 11th, 2015, 05:03 PM
  4. Column analytical model
    By Alexander_Odessa in forum Structure - General Questions
    Last Post: November 25th, 2013, 11:17 AM
  5. Analytical model
    By jbenoit44 in forum Structure - General Questions
    Last Post: June 21st, 2012, 03:34 PM
