Results 1 to 4 of 4
Thread: Create struture beam with varying width on plan
    April 29, 2017
    2
    07:14 AM
    Hi ,
    May I know what is quickest way of creating structure beam with varying width on plan?
    Thanks
    Senior Member
    December 16, 2010
    864
    05:14 PM
    create a custom family - but how is it varying? Is it tapered?
    April 29, 2017
    2
    07:14 AM
    Quote Originally Posted by Karalon10 View Post
    The depth is the same. only the width flared at the one end.
    Senior Member
    December 16, 2010
    864
    05:14 PM
    If it is an unusual case, I would simply model the extrusion "in-situ" using the "component" --> "model in place" tool.
    Set it Under category foundation (or framing if its not a ground beam).
    Then you just draw the flared profile in plan view, set the depth of the element, and you are done.
    Don't forget to set the material to the correct type (same as the slab)
  1. Varying Slope Hipped Roof
    By Building313 in forum Architecture and General Revit Questions
    Last Post: October 7th, 2017, 06:34 AM
  2. Poche doors and display their width dimension on floor plan
    By a1e in forum Architecture and General Revit Questions
    Last Post: August 26th, 2016, 05:20 PM
  3. How can I create a Beam System Tag to show Beam Type Mark or Beam Mark
    By gpktm in forum Structure - General Questions
    Last Post: September 10th, 2015, 04:44 PM
  4. Changing Beam width destroy the join with the Column, Why?
    By dedo in forum Structure - General Questions
    Last Post: July 10th, 2014, 10:23 PM
