Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By elton williams
Thread: Beam with a height parameter in the middle of the beam
    March 16, 2017
    14
    03:38 AM
    I wonder, if there is any possibility to add a parameter in the middle of beam family, which control it's curve? I want middle of my beam, to be 3-5 cms higher than start and end point. Creating beam from a sweep line, in the project enviroment isn't good solution for me.
    I would be thankful for any tips.
    Gold Coast
    2,617
    12:38 PM
    Create a 3point line based curve family, put a parameter driven radial dimension on the curve, works a treat. If I find my way back here tomorrow I'll upload an example
    Andres Franco and Piotr725 like this.
    March 16, 2017
    14
    03:38 AM
    Thanks for answer.
    I created beam which I needed, but it seems that I can't draw beams longer than 8.5-9 meters, cause Revit gives me "can"t make type" error. Do you know how to solve my problem?
    Also I do not know, how to control radial dimension. Changing value puts arc higher or lower and locked constraints, end points, are not satisfied.
    I attached my family, hope that someone knows the answer
    Attached Files Attached Files
    March 16, 2017
    14
    03:38 AM
    Well, the other method dosen't allow me to put 5 cms and create long beams (~14 meters).
    Can someone take a look, maybe I did something wrong?
  1. Beam to Beam or Beam to Column Join Method
    By dedo in forum Structure - General Questions
    Last Post: March 15th, 2018, 11:59 AM
  2. How can I create a Beam System Tag to show Beam Type Mark or Beam Mark
    By gpktm in forum Structure - General Questions
    Last Post: September 10th, 2015, 04:44 PM
  3. Replies: 0
    Last Post: February 25th, 2015, 05:15 AM
  4. Beam with Ledges, How to control the parameter?
    Last Post: August 13th, 2014, 02:06 PM
  5. Beam with Slope in Middle
    By Yan Naing Bo in forum Structure - Family Creation
    Last Post: November 22nd, 2011, 05:55 AM
