Results 1 to 5 of 5
Like Tree3Likes
  • 2 Post By Alex Page
  • 1 Post By cellersick
Thread: Stretchable Span Arrow
    March 1, 2017
    11
    06:31 AM
    Hey guys! New here, been feeding off this forum for a while but ran into an issue I cannot debunk... I'm trying to create a stretchable span arrow to represent my wood truss framing direction. I have been able to create it by going to new>annotation symbol>generic annotation and creating the arrow from there. Well I got the arrow in and looking good but not stretchable... I've been reading a bunch of threads(see below) and for some reason I still can't figure it out. Apparently I need multiple reference planes, not reference lines, and I only have a horizontal and a vertical. I read you can copy and paste them from another family but I've had no luck trying that, I'm in Revit 2016. Here's what it looks like in the image below on plan and the second image is what it looks like in the family.
    Referenced threads that kind of helped but not 100%:
    https://www.revitforum.org/architect...ne-symbol.html
    https://www.revitforum.org/architect...bol-grips.html
    Thanks guys!
    Attached Thumbnails Attached Thumbnails Stretchable Span Arrow-span-arrow.png   Stretchable Span Arrow-span-arrow-family.png
    Senior Member Alex Page's Avatar
    December 13, 2010
    Wellington, New Zealand
    650
    11:31 PM
    The push/pull functionallity doesnt work for annotations unless scale of view is 1:1 - you can still change its length in its instance properties.
    I would suggest you should use the "Detail - Linebased" template instead
    (Also...it doesnt matter if you use reflines instead of planes: I like them since you can then control where the push pull arrows are)
    cganiere and Andres Franco like this.
    March 21, 2013
    Phoenix, AZ
    275
    04:31 AM
    Annotation Symbols *can* be parameterized, but they will only be able to stretch with grips if placed at 1:1. More correctly, they WILL stretch, but you won't be able to control it due to the scaling.
    Detail Components, on the other hand, are much more flexible in terms of what you are looking for. In this case, I'd suggest making the arrowheads a separate family nested within the span arrow. Plus, you can have a line-based DC, which might be a benefit here, similar to attached.
    I don't detail framing, but I thought span symbols were a System family... I'd look into utilizing that first, because the detail component approach isn't tied to the model in any way.
    Attached Files Attached Files
    Andres Franco likes this.
    March 1, 2017
    11
    06:31 AM
    Quote Originally Posted by cellersick View Post
    Ahhhhhhhhh a detail component, that did the trick. Thanks! That one was stumping me. I used the detail item line based and that worked perfect.
    March 1, 2017
    11
    06:31 AM
    Quote Originally Posted by Alex Page View Post
    The push/pull functionallity doesnt work for annotations - you can still change its length in its instance properties.
    Just saw this post as well, that worked, thank you!
  1. Span Direction Symbol
    By yul in forum Structure - Family Creation
    Last Post: October 19th, 2016, 08:40 PM
  2. How i can make the doors and windows is stretchable in plan view?
    Last Post: April 13th, 2014, 02:15 PM
  3. Span Direction Symbols
    By Alex Cunningham in forum Structure - General Questions
    Last Post: September 7th, 2013, 12:07 PM
  4. Truss Span
    By alexo4141 in forum Structure - General Questions
    Last Post: October 24th, 2011, 05:51 AM
  5. How to place an arrow that looks like the text arrow on revit?
    By wjnaim in forum Architecture and General Revit Questions
    Last Post: August 25th, 2011, 07:48 PM
