Results 1 to 2 of 2
Thread: Nested Connection in Structural Framing Family RVT 2016
    May 18, 2016
    1
    04:43 AM
    Hi Guys,
    Hopefully someone can provide some advice.
    I have nested a connection into a beam family and loaded in my project, however once loaded into project the justification of the beam changes and the top up the nested family becomes the justification point. I have tried every approach i can think of to solve this but to no avail. I have attached both families and a couple of screen grabs to describe my scenario.
    Thanks in advance for an potential solutions.
    Attached Thumbnails Attached Thumbnails Nested Connection in Structural Framing Family RVT 2016-beam-project-without-nested-family.jpg   Nested Connection in Structural Framing Family RVT 2016-beam-project-nested-family.jpg
    Attached Files Attached Files
    Member Darius's Avatar
    May 6, 2013
    482
    12:43 AM
    any changes to the beams over all dimensions even threw and nested family that is welded on will change how revit reports top and bottom of the beam. this will effect control purposes however using the spot elevation tool will still get you any elevation that you would need
    Last edited by Dave Jones; January 5th, 2017 at 04:21 PM. Reason: deleted update dup
  1. Structural Framing Based Family
    By navidhedayati in forum Structure - Family Creation
    Last Post: August 17th, 2016, 04:32 PM
  2. 2016 Custom Door Opening Family w/ Nested Lintel Geometry
    By Kyle Roseman in forum Architecture and General Revit Questions
    Last Post: January 28th, 2016, 11:43 PM
  3. Constrain structural framing to r.p. intersection in family
    By byk3bep in forum Architecture and General Revit Questions
    Last Post: March 5th, 2015, 04:04 PM
  4. Cutting voids when nested family in framing family issue
    By jh75 in forum Structure - General Questions
    Last Post: October 23rd, 2013, 05:56 AM
  5. Loading a family from Structural, Framing, Truss Systems category?
    By debshaupt in forum Architecture and General Revit Questions
    Last Post: January 31st, 2012, 08:38 PM
