Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By flayre
Thread: How to make specific parameters within a label invisible.
    December 8, 2016
    1
    04:54 AM
    Hey guys, I'm new here.
    This may be a simple process. Please help me as soon as you can. I would greatly appreciate it.
    http://i.imgur.com/TMxfMEq.png
    So I'm making a window tag for my project. Within the instructions of my professors assignment, we are to keep the type mark visible but every other parameter invisible.
    Within the properties, there's a check mark for "visibility". I unchecked it but when I loaded the tag into the project everything became invisible! Is there a way to keep the type mark visible while making the height, width, and etc invisible?
    May 4, 2011
    110
    05:54 AM
    don't put all of the parameters in the same label. the ones you don't want to be visible, either uncheck visibility or associate with a type parameter that is off for the type.
    look at the out of the box room tag to get an idea as to how you could use Y/N visibility Type parameters and multiple Types inside your tag family.
    cganiere likes this.
  1. Extract specific text from a parameter in properties to Label.
    By Jonatan Eriksson in forum Architecture and General Revit Questions
    Last Post: June 25th, 2017, 08:20 AM
  2. Link label to specific value in panel schedule
    By kalomari in forum MEP - Family Creation
    Last Post: November 24th, 2015, 09:24 PM
  3. Cannot make item invisible in Plan View
    By gpktm in forum Architecture and General Revit Questions
    Last Post: December 16th, 2013, 02:52 AM
  4. Rebar tag with multiple label parameters
    By JasonWallis in forum Structure - General Questions
    Last Post: February 6th, 2013, 11:05 PM
