Results 1 to 6 of 6
Thread: Rebar shape parameters
    November 9, 2016
    1
    09:33 PM
    Hi everyone,
    I'm having trouble creating an extra parameter in a rebar shape family.
    I can only add parameters a to g but I need to ad just one more variable (h).
    Can anyone tell me how to do that ?
    Or is the rebar shape limited from a to g ?
    January 1, 2019
    Szczecin PL/Hamburg DE
    10
    10:33 PM
    Hey
    I do not want to add new thread so I reply to this one.
    I have rebar family as you can see on picures. I wanted to add parameter "X" which correspond to spacing between short ends. Everything goes well, changes implemented, but.... on drawing this dimension is clearly shown as 432 mm, but parameter X equals 490,5, WHY? I have totally no idea, why... Parameter X is shared parameter and described as "reinforcement length".
    Attached Thumbnails Attached Thumbnails Rebar shape parameters-image_2019_03_14t11_06_52_564z.png   Rebar shape parameters-image_2019_03_14t11_07_21_436z.png   Rebar shape parameters-image_2019_03_14t11_07_53_940z.png
    December 11, 2010
    Astana
    125
    02:33 AM
    I think this case should be sent to Autodesk.
    Autodesk TheViking's Avatar
    Lexington, MA
    157
    04:33 PM
    Rebar does not "flex" in the family like other Revit families. This allows for overlapping segments. To see how the bar behaves load it into the project and flex it is a large space. I typically place one in a floor and vary the properties to see how the bar behaves.
    December 11, 2010
    Astana
    125
    02:33 AM
    It seems that when you "overconstrain" a rebar sketch, the dimensions become unpredictable. If you remove H, K parameters, X will show the correct value.
    Lexington, MA
    157
    04:33 PM
    I think you will find the numbers report correctly in the project, but if this approach works for you then great!
  1. Revit Rebar Shape Parameters
    By joefell_21 in forum Structure - Family Creation
    Last Post: December 23rd, 2015, 02:21 PM
  2. rebar shape
    By stefano.88 in forum Structure - General Questions
    Last Post: July 22nd, 2015, 12:55 PM
  3. How to export Rebar shape in Rebar schedule?
    By phamtuan in forum Structure - General Questions
    Last Post: March 18th, 2013, 03:10 PM
  4. Square Rebar Shape
    By adrian7476 in forum Structure - General Questions
    Last Post: July 13th, 2012, 12:28 AM
  5. S3 Rebar Shape DC
    By gdoherty0102 in forum Architecture - Family Creation
    Last Post: March 30th, 2012, 12:06 PM
