Results 1 to 4 of 4
Thread: Concrete beam won't join
    August 25, 2015
    34
    05:25 PM
    Hello, iv'e managed to create a beam just the way we need to (including grips and stuff). Only thing is we can get it to join others/similar beams. Does anyone know how this might be fixed?
    thanx in advance
    Attached Files Attached Files
    Member Darius's Avatar
    May 6, 2013
    482
    12:25 PM
    revit is very exacting with this the surface & cut pattern must be the same as what you are joining it to as well as the materials for them to join with out lines as you are expecting
    August 25, 2015
    34
    05:25 PM
    I know, but not even 2 beams of the one I posted join.
    May 6, 2013
    482
    12:25 PM
    are they exactly the same height and width any small difference between the two will cause a line where u would want them to join
  1. Beam to Beam or Beam to Column Join Method
    By dedo in forum Structure - General Questions
    Last Post: March 15th, 2018, 11:59 AM
  2. Concrete beams do not snap and do not join
    By gpktm in forum Architecture and General Revit Questions
    Last Post: October 28th, 2015, 03:00 AM
  3. beam join issue
    By Ning Zhou in forum Structure - General Questions
    Last Post: July 11th, 2014, 09:07 PM
  4. Concrete join orders in 2014
    By jh75 in forum Structure - General Questions
    Last Post: May 27th, 2013, 02:52 PM
  5. Replies: 0
    Last Post: September 28th, 2011, 04:00 PM
