Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By elton williams
  • 1 Post By anuj
Thread: Colum based genaric model
    July 20, 2016
    2
    09:29 PM
    Hi All,
    I am new in Revit, I have one query, I need to create one generic model which suppose to be column based.
    Tts host should be column only, and it should read parameter of column and behave according to that.
    Current templates available are Wall based , floor based faced base but not colum based.
    Is it possible?
    Thanks in advanced.
    Gold Coast
    2,617
    07:29 AM
    No such thing as column based family template. Use face based. Depending on the data you need to read and how you need it displayed, would determine how you build this family and whether it should be nested in the column family or loaded separately into the project.
    Need more info on what you are trying to achieve.
    anuj likes this.
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    348
    09:29 AM
    Opening Post - If your meaning you want Family that Acts like a Column, but is a Generic Model Category, then yes you can do that (we have done this for Downpipes)
    Open up the Column Family, and then change the Family Category (The Yellow Icon) to whichever you want.
    If your meaning a Family that Stick to a Column (Column Hosted) then I agree with Elton
    July 20, 2016
    2
    09:29 PM
    thanks for the reply.
    Actually I want to make corbel and that should read column Size and according to that it should behave.
    Currently I am using face based family.
    as per your comment "No such thing as column based family template" then I got my answer.
    elton williams likes this.
  1. aligning colum with grid
    Last Post: July 6th, 2017, 11:59 AM
  2. Creating a floor based and wall based generic model in a single family
    By PraveenPonnuru in forum Tutorials, Tips & Tricks
    Last Post: September 10th, 2015, 04:16 PM
  3. Generic model wall based
    By dmodomino in forum Structure - General Questions
    Last Post: August 27th, 2015, 07:35 PM
  4. joining colum with beams
    By Nsync in forum Structure - General Questions
    Last Post: December 8th, 2013, 12:25 PM
  5. How is Generic Model Pattern Based different from Curtain Panel Pattern Based
    By shtirlits in forum Architecture - Family Creation
    Last Post: October 5th, 2012, 12:14 AM
