Results 1 to 2 of 2
Thread: Structural columns and lookup tables
    April 1, 2015
    1
    05:18 AM
    Hi everyone
    I have been doing some structural columns and framing. I have made a type catalog so its easier to only import the columns I need for a certain project.
    The challenge is I dont know what is wrong with the attached file from UPN 240 and above sizes. Have anyone encountered similar problems or did I do something wrong in the type catalog.
    All files used to make these are attached.
    BR
    Jesper
    Attached Files Attached Files
    Junior Member mfleming's Avatar
    January 31, 2014
    15
    10:18 PM
    Hi Jesper,
    It appears to be the fine level detail that breaks.
    I recommend re-building the family from scratch using sweeps and profiles.
    If you are attached to this family, start looking at the inside corner radius. See image below.
    Good luck. (Profile image on left is a simpler approach and reduces performance hits on the model with less curves)
    Matt
  1. Lookup Tables
    By knkagaki in forum MEP - Family Creation
    Last Post: July 17th, 2015, 07:49 AM
  2. Lookup Tables: how to skip a search value
    By Clogboy in forum MEP - Family Creation
    Last Post: February 12th, 2015, 09:47 AM
  3. Calling out Lookup Tables
    By BarryMClark in forum Architecture - Family Creation
    Last Post: January 11th, 2015, 02:14 PM
  4. Replies: 0
    Last Post: June 21st, 2013, 07:45 AM
  5. I don't get lookup tables
    By narlee in forum MEP - General
    Last Post: May 1st, 2013, 05:09 PM
