Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Robin Deurloo
Thread: Parameters.....Need assitance
    Junior Member lukemcgary's Avatar
    March 3, 2016
    North Carolina
    12
    01:16 PM
    Hey everyone, I have got some questions about parameters and what i can actually accomplish. I have given an image below for and example and the highlighted areas are what id like to give associated ranges to.
    First off i wanna make multiple copies of the family, 2WG, 3WG, 4Wg, etc.
    for instance if my height or depth is 0-14 i want my connectors to know it is S & Drive, and if its 15-26 that it is T-bar, as well as if one side (width or Height is equal to those arranged numbers it will give both connector name 1 & 2, S & Drive or T-bar.
    Also the gauge is based on another factor of numbers as well so i want to somehow get these to use a formula to give the right answer
    Is there a way to do this, I do know geometry is involved somehow but i am ignorant on that subject. Is there an easier way to have revit figure these out. We do use sysque but even then it makes our job a mess when it enters there generics into our routing preferences so i want a work around so basically all i have to do is manually break the duct up into our set lengths and then send it to he fab shop.
    Any advice or assistance will be helpful, i am spending each day slowly researching and trying to understand revit yet im a noob.
    July 7, 2011
    Rotterdam, Holland
    1,235
    07:16 PM
    no image ...
    March 3, 2016
    North Carolina
    12
    01:16 PM
    Parameters
    I need to know if there is a way to enter different varibles for the connector types to be based on the width and depth
    July 7, 2011
    Rotterdam, Holland
    1,235
    07:16 PM
    You can use various IF THEN ELSE formula's in your parameters, so yes possible but might be a bit of work.
    Something like IF (Width = 6 AND Depth = 7, X, Y)
    So in this case if the width is 6 and the depth is 7 the value will be X if not then it will be Y. And you can use nested IF statements too.
    But I can better point you to the 'Revit Formulas for "everyday" usage' thread, Munkholm is much better in explaining it then me.
    http://www.revitforum.org/tutorials-...day-usage.html
    Dave Jones likes this.
  1. Mapping Revit parameters to IFC parameters
    By tuekappel in forum Architecture and General Revit Questions
    Last Post: January 31st, 2016, 08:33 PM
  2. Replies: 0
    Last Post: February 11th, 2015, 03:45 PM
  3. Shared Parameters or Project Parameters?
    Last Post: November 7th, 2013, 02:14 PM
  4. Replies: 0
    Last Post: August 15th, 2013, 12:15 AM
  5. Import shared parameters into an existing shared parameters file
    By Ree in forum Architecture and General Revit Questions
    Last Post: January 14th, 2013, 09:34 PM
