Results 1 to 2 of 2
Thread: Change rebar layout direction
    November 20, 2015
    3
    09:24 PM
    Is there a way to change the direction of rebars being layed out?
    In my case, I want to place rebar shape 21 "shoulder to shoulder" in the edge of a slab. This is the case marked green in my illustration. Earlier I've solved this by placing every single rebar, but this in very uneffective. A solution is the Array-function, but I would prefer using the default layout function where maximum spacing etc is the only parameters. What Im thinking is to flip the layout-face of the rebar, sp
    The red and blue is just rebars placed with the preferred function, but in wrong direction.
    Hope someone have an answer!
    Arne
    Attached Thumbnails Attached Thumbnails Change rebar layout direction-skjermbilde.jpg
    Senior Member
    December 16, 2010
    856
    07:24 AM
    Quote Originally Posted by arsa View Post
    Arne
    You need to edit the shape / sketch of your slab.
    There you will see "span direction" and this defines the position of your first layer of reinforcement.
    Just edit your slab, click on "span direction" and select a line perpendicular to the current choice.
    Finish the "sketch" and try placing reo again it should update your laying sequence.
  1. Why Array is happening in two direction instead of one direction ?
    Last Post: January 2nd, 2016, 10:54 AM
  2. Rebar layout face/direction
    By arsa in forum Structure - Family Creation
    Last Post: December 12th, 2015, 03:37 AM
  3. Making rebar grade come before rebar diameter in annotation label
    By einsteino in forum Structure - Family Creation
    Last Post: September 22nd, 2015, 02:12 PM
  4. how could we change rebar bar system ???
    By Eng.N.3D.All in forum Structure - General Questions
    Last Post: August 29th, 2014, 06:53 PM
  5. How to export Rebar shape in Rebar schedule?
    By phamtuan in forum Structure - General Questions
    Last Post: March 18th, 2013, 03:10 PM
