Results 1 to 7 of 7
Thread: flip family before placing family?
    JWR
    JWR is offline
    February 2, 2011
    Rotterdam
    30
    06:10 PM
    Is it possible to flip a family before placing it?. I work with a lot of void family's in Structural family's if the orientation is wrong can not cut.....
    Like the space bar fot rotate.
    Senior Member
    December 16, 2010
    849
    03:10 AM
    It would depend on the context of your family.
    Assuming it has "controls" built into the family, tapping space bar will cycle through the placement options.
    If it is a void family, I have noticed a particular void family that was placing automatically with another add-in software that would place badly if the orientation was not properly managed during the placement of the family - yes your void family will need to be oriented properly or it will cut nothing....
    JWR
    JWR is offline
    February 2, 2011
    Rotterdam
    30
    06:10 PM
    Thanks for your reply. Your text is clear for me.
    Mine question is there a "space bar" like your description to flip the void before placing it. Like tapping the space bar to rotate. I want to flip.
    Senior Member
    December 16, 2010
    849
    03:10 AM
    it will depend on your void family.
    if you can, edit the family and under "create" tab, add a direction control (depending what you need, either vertical or horizontal control). Load the family back into your project and see if this gives you the control you want.
    The ability to flip the object must be included in the family itself.
    Generally the family will flip around the face of its host or perhaps the midline of the family. It will all depend on how the family has been designed really.
    So for example if the host is the face of a wall, flipping the family will flip it with the face as the pivot point.
    JWR
    JWR is offline
    February 2, 2011
    Rotterdam
    30
    06:10 PM
    flip family before placing family?-capture.pngPerfect description again. But.
    I try to make it work from two side off the family.
    We use a family to make a hole (blue).
    From de red side it goes good from the green side it does not. I can flip the family after i placed it on de red side and i get de errror can not cut. That is oke for me.
    I try to refrase the question. Can i flip the family before placing it and with buttons do i use?
    Gold Coast
    2,601
    03:10 AM
    Quote Originally Posted by JWR View Post
ID:	26723Perfect description again. But.
    Flip controls only work in plan (spacebar). Either make the void in your family extrude in both z directions or create a second void geometry and family type with a yes/no type visibilIity parameter to switch between the two. Then in project select correct type from the dropdown before placing.
    Senior Member
    December 16, 2010
    849
    03:10 AM
    Ok that confirms for me that your void places from the face of the object downwards.
    I'm not sure why this is an issue, just always place your voids in a plan view.
    But I would question why use a void family at all? You can use a cage opening and have this traverse multiple levels all at once.
    I have seen an add-in (MagiCAD) Logiciel de CAO pour l'ingénierie du bâtiment avec Revit | MagiCAD
    This addin will automatically place voids (using a similar void family) but it is predominantly designed for MEP and not structure.
    This add-in works well actually, you set a few rules (clearance around pipes/ducts for example) and it will punch holes through elements based on those rules but it does need a bit of micromanaging to get it to work nicely at the start. I used this add-in at another firm (actually I work in structures and I helped an MEP guy with the issues it was creating)
    One of the main issues it was having was as you describe, with void families doing weird rotations and this all had to do with which side of the slab/wall they were placing their void from.
  1. Flip Control in a Generic Model Family?
    By Dave Jones in forum Architecture - Family Creation
    Last Post: December 8th, 2015, 11:08 PM
  2. Trouble placing a Family
    By Lox in forum Architecture and General Revit Questions
    Last Post: April 8th, 2013, 10:26 PM
  3. Flip Control Within an Embeded Family
    By DGoffron in forum Architecture - Family Creation
    Last Post: November 1st, 2012, 03:16 PM
  4. Placing family to the top of wall!?
    By Parametric Snowman in forum Architecture - Family Creation
    Last Post: June 14th, 2012, 06:59 PM
  5. Family placing error
    By bangobeat in forum Architecture - Family Creation
    Last Post: July 25th, 2011, 09:42 PM
Tags for this Thread
