Results 1 to 5 of 5
Thread: Section Line
    September 1, 2014
    27
    03:01 AM
    Section Line
    Can anybody help me with having one section line where one side is straight and other side is angled 9o degrees. this all going to be as one section.
    Member Darius's Avatar
    May 6, 2013
    484
    11:01 PM
    do u want a 90 degree section?
    If thats what your after your best bet is a 3d
    U will not be able to make a 90 degree section
    Senior Member
    December 16, 2010
    856
    01:01 PM
    The only way you would be able to do this, is to have a 2D element which would not be an "intelligent" section marker.
    ie. It would not automatically reference the page it is on, or the detail numbers and would not actually link to your view it would be a "dumb" 2D element.
    Unfortunately, as far as I am aware, you can not dislocate or "jag" your sections in revit they are linear (straight lines) only
    September 16, 2015
    Darwin, Australia
    171
    01:31 PM
    You can split the section line with the Split Section function in the Modify tab while you have the section line selected. It is mostly used to vary the section elevation in the view, which can be handy sometimes. I don't know why you would need it to bend 90° though. You can modify the section tail element of the section in the family editor and do what you want with it there, but it will not actually affect the view. Like Darius said, it sounds like you want a 3D section.
    Whatever you decide to do, good luck.
    Senior Member Alex Page's Avatar
    December 13, 2010
    Wellington, New Zealand
    649
    03:01 PM
  1. Section head and section line control
    By jpeter78 in forum Architecture - Family Creation
    Last Post: January 22nd, 2016, 03:56 PM
  2. Different line styles for Bulding section vs Wall section
    By NW_Reviteer in forum Architecture and General Revit Questions
    Last Post: November 13th, 2012, 09:17 PM
  3. Replies: 0
    Last Post: August 30th, 2012, 05:15 AM
  4. How to duplicate section so section line wouldnt appear
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: January 10th, 2012, 10:18 PM
  5. section line - clip without line reset
    By redmonki in forum Architecture and General Revit Questions
    Last Post: December 9th, 2011, 08:17 PM
