Results 1 to 3 of 3
Thread: sketching rebar and scheduling
    March 11, 2016
    5
    04:36 AM
    How do you know what segments of rebar created in sketch mode are scheduled under corresponding letters (A-H) in a schedule? what if there are more segments than scheduable letters? If I try to open rebar I've created in sketch mode it crashes revit and prompts me to save a recovery file. Otherwise I would have used that to look at the parameters.
    thanks
    Senior Member
    December 16, 2010
    856
    08:36 PM
    good question, never tried this sketch mode out BUT
    I can say that 99.99% of problems in revit - the solution is somewhere in the properties box.
    If it is not there the other 0.01% of cases, its in the "family" itself.
    Member byk3bep's Avatar
    January 30, 2014
    449
    11:36 AM
    Open the family editor to see the letters that correspond the segments.
  1. Making rebar grade come before rebar diameter in annotation label
    By einsteino in forum Structure - Family Creation
    Last Post: September 22nd, 2015, 02:12 PM
  2. Replies: 0
    Last Post: May 1st, 2015, 12:15 PM
  3. sketching in place masses...
    By ethank in forum Architecture and General Revit Questions
    Last Post: October 29th, 2013, 03:36 PM
  4. Sketching a Scroll
    By Randy_CaS in forum Tutorials, Tips & Tricks
    Last Post: September 2nd, 2011, 01:34 PM
  5. Sketching the center line of a retaining wall
    By Ali Akbar in forum Structure - General Questions
    Last Post: April 14th, 2011, 12:35 PM
