Results 1 to 2 of 2
Thread: Concrete beam acts weird
    August 25, 2015
    34
    05:54 PM
    So, i've created a concrete beam, started from Generic model, line-based. Works nice, but its just this one thing i cant figure out; when i place the beam in my project, the work plane is 9/10 the bottom of a floor, but i want it to be a level.
    Weird thing is, when i load it into a new project, it connects just the way i want it....??? (see attached file).
    Any help would be nice!
    (Revit structure 2016)
    Attached Files Attached Files
    Senior Member
    December 16, 2010
    849
    02:54 AM
    just had a really quick look at this family.
    what you have created here is an upstand beam.
    it has a positive extrusion value (ie it extrudes vertically upward)
    If you open your family and go to an elevation.
    You can see that it places the BOTTOM FACE of the beam, on the level you are working on.
    If you want it to go the other way, you need the TOP FACE of the beam to be touching the reference plane, and the object should extrude downwards from that reference plane.
    Actually what you have done is fine for an upstand beam (save it and name it as such)
  1. Concrete beam schedules?
    By LeanneZ in forum Structure - General Questions
    Last Post: January 26th, 2016, 02:31 AM
  2. BIM & Beam: Open Discussion on Advance Concrete
    By BIM & Beam in forum Blog Feeds
    Last Post: April 26th, 2015, 11:15 PM
  3. Concrete beam to column connection
    By ahmed_nox in forum Structure - General Questions
    Last Post: September 15th, 2014, 06:09 AM
  4. Chamfers to a concrete beam?
    By BigIdiot in forum Structure - Family Creation
    Last Post: September 11th, 2014, 12:20 PM
  5. Cantilever Concrete Beam
    By gdoherty0102 in forum Structure - General Questions
    Last Post: November 15th, 2012, 08:40 PM
