Results 1 to 6 of 6
Thread: Help w/ Structural Framing
    August 3, 2015
    115
    04:01 AM
    I brought in an OOTB piece of c-channel. The insertion point is such that when the c-channel is laying on-end, the top end of the c-channel is lined up to the bottom of the floor. I need just the opposite; the bottom end of the channel laying on top of the floor.
    I know very little about family modification so I would appreciate any advice on how to accomplish this. On opening the family there are several work planes associated to different things. Once I break the constraints and move the channel to the proper plane, I can't put humpty dumpty back together again.
    Gold Coast
    2,617
    09:01 PM
    Quote Originally Posted by mdomer View Post
    Structural families are a breed of their own and if you start shifting things around inside the family without knowing what you're doing things can get messy really quickly, as you have discovered.
    In the project, select the structural member and start to get familiar with the instance parameters. Here you will find rotation parameters and justification parameters.
    Member Darius's Avatar
    May 6, 2013
    484
    07:01 AM
    in structural families there is a paramerter section called geometric position try adjusting those parameters to see if that helps before you modify the families.
    also the parameter called cross section rotation will spin the beam on its horizontal access
    Member byk3bep's Avatar
    January 30, 2014
    449
    12:01 PM
    This is what you are after i guess
    Help w/ Structural Framing-ss1.jpg
    August 3, 2015
    115
    04:01 AM
    Quote Originally Posted by byk3bep View Post
    That's it!
    Thank you! So simple
    Senior Member
    December 16, 2010
    856
    09:01 PM
    with structural framing a few important things to help you out.
    In general when troubleshooting -
    Most problems (99.99% of them you can possibly encounter) with framing is going to be manageable in the element properties box.
    If it is not in the properties box, the final solution/problem will be in the family itself.
    You can place sloped reference planes to place things like rafters, and purlins easily.
    Simply name your reference plane (logically) for example "roof grid a to grid c" and then you can define this reference plane as a work plane before placing your framing. (don't forget to redefine it to a level once you are done placing on that slope)
    You have a few options in the properties box that are really useful
    X, Y and Z offsets.
    "Z Justification" (place on centreline, top of beam, or bottom of beam") This is the one you needed to adjust for your current problem - however you could have also managed this by altering your Z offset. I prefer to set the justification correctly as it is easier to manage, rather than a Z offset.
    Also for example with the "Z justification" I would set my rafter to place on that sloped reference plane at "top of beam" and my purlin I would place using the very same reference plane and set it to justify at the "bottom of beam" plus perhaps an offset of 10mm if I really want to model exactly with my purlin cleats etc included.
    Also there is a "rotation" option available
    Note that things such as rotation, and Z offset, will be affected directly by the justification.
    For example the pivot point for the rotation of an object, rotates around the Z justification as the centre-point of the rotation.
  1. How to copy/monitor structural foundation and structural framing?
    By michalnykiel in forum Architecture and General Revit Questions
    Last Post: September 23rd, 2015, 01:37 PM
  2. Replies: 0
    Last Post: May 2nd, 2015, 01:18 AM
  3. Structural Framing export to CNC
    By boom02 in forum Structure - Family Creation
    Last Post: December 17th, 2013, 12:53 PM
  4. Structural Framing
    By DD1 in forum Structure - General Questions
    Last Post: June 15th, 2012, 06:52 PM
  5. structural framing tag
    By r7_human8y in forum Architecture and General Revit Questions
    Last Post: December 6th, 2011, 05:59 PM
