Results 1 to 2 of 2
Thread: 2D Lt Ga Stud - Parametric Array of Bracing Openings?
    Member RsqPrincess's Avatar
    October 3, 2011
    Wisconsin, USA
    60
    04:12 PM
    I've been using this 2D lt ga stud family for a while. I'm now trying to add a parametric array of bracing openings that will automatically add in along the length as the detail item is drawn.
    I've gotten it to the point that the bracing openings will appear based on length and that the spacing can be controlled.
    Here's the trouble:
    If the stud is drawn shorter than about twice the "bracing opening spacing", revit says that it cannot be drawn. I know it has to do with how i worded my formulas (by including "length"?), but this has been driving me crazy for hours and i'm just not getting anywhere.
    I'm hoping that one of you who is more experienced than I in family creation point me to where I've gone wrong! I'd be grateful for any advice you can give.
    Thank you!
    Attached Files Attached Files
    10,178
    04:12 PM
    I haven't downloaded it, but I'm assuming you have an array in there for the bracing? If so, you have to do what I call the *single alt* setup:
    1. Place a single instance of brace
    2. Additionally, place the array.
    3. Constrain the single instance where it would go if there was only one brace.
    4. Set up a parameter *instancevis*
    5. Set up a parameter *arrayvis*
    6. Set up a parameter *array count*
    7. Set up a parameter *array count act*
    8. Use array count act in your array.
    9. Array count act formula: if (array count>1, array count,2)
    10. arrayvis=array count>1
    11. Instancevis=array count <2
  1. Parametric Array with a value of 1?
    By KWilkinson in forum Architecture and General Revit Questions
    Last Post: June 26th, 2018, 08:46 PM
  2. Parametric XY Array
    By kowen1208 in forum Architecture - Family Creation
    Last Post: December 3rd, 2013, 02:19 PM
  3. Parametric Array Families
    By chuckyd67 in forum Architecture - Family Creation
    Last Post: November 20th, 2012, 07:02 AM
  4. Parametric Array
    By Andres Franco in forum Architecture and General Revit Questions
    Last Post: November 15th, 2012, 06:24 PM
  5. Stud array on beam issues
    By joshr in forum Structure - Family Creation
    Last Post: August 9th, 2012, 05:35 PM
