Results 1 to 2 of 2
Thread: View Title - Add instance parameter editable in project
    March 30, 2016
    5
    04:19 PM
    In lieu of using the default extension line in view titles, I drew a line in the view title family and used an instance parameter to control the length of the line. The line length flexes correctly while inside the view title, but once loaded into the project, the instance parameter does not show up inside the project when a view is selected. What do I need to do?
    In the past I created separate view title family types with different view title line lengths, but if it's possible to do the same with just an instance parameter, it would be more streamlined and flexible.
    Thanks.
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    341
    04:19 AM
    I think your out of luck there
  1. View Title with Label with Text Parameter?
    By blusurfer in forum Architecture - Family Creation
    Last Post: November 6th, 2017, 10:12 PM
  2. Parameter in View Title
    By ekelsey15 in forum Architecture and General Revit Questions
    Last Post: August 11th, 2015, 01:09 PM
  3. Replies: 0
    Last Post: August 26th, 2013, 07:45 AM
  4. Including instance parameter in type parameter formula
    By sabari2504 in forum Architecture - Family Creation
    Last Post: August 12th, 2013, 02:54 PM
  5. Add Parameter to Family Category - View Title
    By devinmccarthy in forum Architecture - Family Creation
    Last Post: January 17th, 2012, 10:18 PM
