Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By cellophane
Thread: Door with Beam (lintel)
    February 1, 2016
    4
    10:45 PM
    Hello
    I would like to create a family of doors with a beam (lintel) above the doors, but the beam height be constraints by the upper reference level. Already grateful for your help to guide me in this family.
    Thank you.
    February 1, 2016
    4
    10:45 PM
    Hello again
    I found something very similar tried to talk to him, but did not get any response.
    https://www.youtube.com/watch?v=1wQfzEx2Evc
    http://plevit1.blogspot.pt/2014/03/m...ed-family.html
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    05:45 PM
    You can control the lintel height above floor and member height in the door family but as far as I know doors don't have a way to pull from a level other than their host in the same way a column or wall can.
    marino melo likes this.
    Senior Member
    December 16, 2010
    856
    07:45 AM
    Yeah have to agree you can't really manage what you are asking because the object you are hosting to has no real reference to the level above....
    actually just brainfarted on this right now, if you construct your walls from the level ABOVE (and use the place with a depth rather than a height functionality), you may be able to have your opening "push" from this level "above" but you would also need to redesign your opening family with this in mind.
  1. 2016 Custom Door Opening Family w/ Nested Lintel Geometry
    By Kyle Roseman in forum Architecture and General Revit Questions
    Last Post: January 28th, 2016, 10:43 PM
  2. how dropping a concrete beam over a Masonry opening (to create lintel)
    By sophia0219 in forum Structure - General Questions
    Last Post: January 6th, 2015, 03:13 PM
  3. Radial Arrays - Brick Arch Lintel
    By Number 7 in forum Architecture - Family Creation
    Last Post: February 12th, 2013, 12:18 AM
  4. Lintel Opening in Wall
    By ParagonChris in forum Architecture - Family Creation
    Last Post: January 31st, 2012, 09:09 PM
  5. parametric arched lintel difficulties
    By jordan in forum Architecture - Family Creation
    Last Post: August 20th, 2011, 01:30 AM
