Results 1 to 3 of 3
Thread: Can't add parameter to rebar angle dimension
    February 3, 2016
    2
    10:49 AM
    Hey guys.
    I'm relatively new to Revit families, and an absolute newbie with Rebar families, so I'd love some help
    I have some rebar shapes that were created via sketch, and have no problems getting the various parameters to the linear dimensions.
    A through R are available, and I can easily add A to one leg and B to the next leg.
    However, when I put in an angular dimension, to get the angle into the schedule, I am unable to add any parameters to that dimension.
    Is there some reason why there's a difference between the linear and angular dimensions?
    Attached Thumbnails Attached Thumbnails Can't add parameter to rebar angle dimension-revit-rebar.png
    September 16, 2015
    Darwin, Australia
    171
    09:19 PM
    Have you checked your 'I' parameter to ensure it is an Angle parameter and not a Length parameter. If this is the case then it would be an easy fix. The reason you can't create a new parameter is because you have the Shared Parameter box checked, click on the Family parameter instead. Since your new to families overall, I wouldn't recommend playing with Shared Parameters just yet.
    Good luck, I hope I could help.
    February 3, 2016
    2
    10:49 AM
    Thanks for the reply Luke.
    What do you mean by checking the I parameter? There are no parameters available for angle dimensions. Not the I, nor any of the other ones. And as you see in the picture the Family/Shared Parameter checkboxes are greyed out, so there's no way for me to choose Family Parameters.
  1. 2D family with angle parameter refuses to work
    By phoulx in forum Architecture - Family Creation
    Last Post: June 3rd, 2016, 10:31 PM
  2. Replies: 3
    Last Post: April 20th, 2015, 01:24 PM
  3. Architect's opinion on how to dimension an angle wall
    By tzframpton in forum Architecture and General Revit Questions
    Last Post: August 29th, 2013, 03:13 PM
  4. Ref lines moving along angle parameter
    By Goahead in forum Architecture - Family Creation
    Last Post: August 8th, 2013, 07:58 PM
  5. Angle Parameters - Cant align a dimension in a generic model family
    By sambarr88 in forum Architecture - Family Creation
    Last Post: July 21st, 2013, 10:56 PM
