Results 1 to 3 of 3
Like Tree5Likes
  • 2 Post By Andrew K
  • 3 Post By Twiceroadsfool
Thread: Bi-Fold Door Problem.
    Member mark2009's Avatar
    May 27, 2015
    106
    11:40 PM
    Question Bi-Fold Door Problem.
    Hey guys,
    I would like to know how to integrate bi-fold movement as in chancing the length so the angle moves with the length and is not still so it doesn't cross hatching in between each other.
    Senior Member
    August 19, 2011
    New Hampshire
    503
    07:40 AM
    This is how I did one client, stripped down to show the parts you need. I believe I borrowed the procedure from somewhere else and improved upon it.
    Pay attention to the parameters in 'Constraints' to control the angle movement and the Panel Gap parameter in 'Dimensions' to control control spacing between the panels. The way I have it set now is to sit wider when open 90 degrees to get the appropriate clearance space necessary.
    Attached Files Attached Files
    mark2009 and Bross like this.
    10,175
    06:40 AM
    If you dont mind doing some trig, it gets much easier to set up.
    Video with the Bi fold panels moving based on a percentage: https://www.youtube.com/watch?v=I1HxzW08RCM
    But there are a few things to keep in mind:
    1. The panels connect to each other on a different plane than the connect to the common point (the track), so the triangle you are forming isnt the simple one it appears to be. Because of that, its easier to think about it as a line across, with two ends on it, than as the "panels" being connected.
    2. You have to make it *jump* over the first few degrees. A bi-fold door opened 1-2% doesnt actually fit in its opening, because of the first issue.
    3. Youll need Reference Lines, and then its easier to make them the workplane of the item you are trying to host.
    Attached Thumbnails Attached Thumbnails Bi-Fold Door Problem.-2016-02-02_15-13-07-formulas.jpg
    mark2009, cganiere and pksimon2007 like this.
  1. Door Problem
    By BarisErtas in forum Architecture and General Revit Questions
    Last Post: January 20th, 2016, 09:03 AM
  2. floor finishes and door problem
    By angelobacc88 in forum Architecture and General Revit Questions
    Last Post: September 5th, 2014, 03:12 PM
  3. Door curtain wall problem....help pls.....
    By mig3d in forum Architecture - Family Creation
    Last Post: February 16th, 2014, 11:58 PM
  4. display problem with my window/door
    By boriskam1991 in forum Architecture and General Revit Questions
    Last Post: April 4th, 2013, 09:20 PM
  5. Curtain panel door problem
    By Tomcsie in forum Architecture and General Revit Questions
    Last Post: October 19th, 2012, 02:40 PM
