Results 1 to 2 of 2
Thread: How do I modify (or turn off) the structural framing auto-join feature
    Member ecraider's Avatar
    May 19, 2014
    Concord, CA
    87
    09:57 AM
    I am using structural framing members to create joist layouts for CFS metal Joists.
    I have created a system that works really well using beam systems, however sometimes my Joists autojoin to each other from room to room. This causes me to have to go in and reset the systems and sometimes to unpin and unjoin members to get them to work properly.
    I was thinking of possible using a Structural framing family as a shell, with a nested generic model family that will actually represent my joists.... not sure that it will work.....
    Easiest solution would be to simply turn off autojoin and wherever I set my Beam System boundary will be the extent of my joists. Is this possible?
    Any advice is greatly appreciated.
    Member Darius's Avatar
    May 6, 2013
    482
    05:57 AM
    did u try turning off the analytical model?
  1. How to copy/monitor structural foundation and structural framing?
    By michalnykiel in forum Architecture and General Revit Questions
    Last Post: September 23rd, 2015, 01:37 PM
  2. Wall Section: Modify Vertical, now plans don't join
    By Damo in forum Architecture and General Revit Questions
    Last Post: July 24th, 2015, 08:59 AM
  3. Replies: 0
    Last Post: May 2nd, 2015, 01:18 AM
  4. Beam auto join drive me to the maddness
    By tussyswat in forum Architecture and General Revit Questions
    Last Post: February 25th, 2015, 04:42 PM
  5. Avioding auto-join with Hollow core slab?
    By Profiil in forum Structure - General Questions
    Last Post: November 27th, 2013, 02:45 AM
Tags for this Thread
