Results 1 to 9 of 9
Like Tree6Likes
  • 1 Post By snowyweston
  • 2 Post By Steve_Stafford
  • 1 Post By tuekappel
  • 1 Post By Steve_Stafford
Thread: Reference Line keeps breaking
    Member mark2009's Avatar
    May 27, 2015
    106
    07:39 PM
    Hey guys,
    Can someone please help me. Why is it when i change my angle input to 0 then change it back to 45 the reference line breaks.
    Reference Line keeps breaking-reference-line-breaks.jpgBRAKES.rfa
    December 21, 2010
    C.LONDON
    4,392
    08:39 AM
    Angular dimension(al) constraints are notoriously picky when they reach the 0 and 90 quadrants.
    Some (including myself) use 'limiters' (an angle-dim-locked ref. line 'tied' to the primary) that restricts the angle from ever 'truly' being 0 (or 90) whilst returning the same (visual) effect....
    Some others employ a slightly nattier approach using arc angles - with elements hosted on/to a curved reference-line - that (apparently) is a bit more robust.
    Either way, plenty of discussion on the very same topic has been posted here, have a nose around some old threads...
    mark2009 likes this.
    Mr. Revit OpEd
    2,910
    12:39 AM
    Generally such finicky behavior will work correctly in the project while breaking in the family editor. Try it in a project, you'll probably find it works.
    Revit's own internal Automatic Sketch Dimensions (ASD) are based on orthogonal relationships. When you change the angle to 90 degress the ASD's change what they reference. You can see this if you turn them on (V/G Annotation Categories tab) in the family editor plan view. Notice where they appear and then change the angle to 90 degrees.
    mark2009 and pksimon2007 like this.
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    334
    07:39 AM
    Red face
    This tutorial:
    Revit OpEd: A Doors Life
    -opened my eyes to the more intricate techniques in family modeling, and it adresses the above-mentioned problem. -The angular dimension drives a ref plane in the nested family, the ref plane is skewed 5º. So the driving parameter is -5º when the door is shut, and 85º, when the door is 90º open.
    [Edit: oh, Hi, Steve ]
    May 27, 2015
    106
    07:39 PM
    Everyday is always a problem with revit I notice that yesterday it worked on project, but was curious if it was fixable in family.
    Mr. Revit OpEd
    2,910
    12:39 AM
    Quote Originally Posted by mark2009
    ...but was curious if it was fixable in family...
    You can control it IF you can eliminate the ASD's changing by providing the constraints Revit needs to keep the endpoints of the Reference Lines in the same location as the angles and lengths change. The ASD's only appear when there is ambiguity.
    Personally, I'd just ignore the issue in the family (by not testing it at 90 degrees) since it works where it needs to work...in the project.
    May 27, 2015
    106
    07:39 PM
    noob question what does ASD stand for?
    December 21, 2010
    C.LONDON
    4,392
    08:39 AM
    Automatic Sketch Dimensions.
    (we should probably add it to the forum abbreviations and keywords)
    May 27, 2015
    106
    07:39 PM
    Thank you
  1. Reference line orientation with 3d snapping
    By efebei in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: July 1st, 2015, 08:53 PM
  2. Reference line
    By mona.miller in forum Architecture and General Revit Questions
    Last Post: August 26th, 2014, 03:23 PM
  3. Re - Concept mass - Reference Line from CAD
    By juangambino in forum Structure - Family Creation
    Last Post: February 9th, 2012, 08:15 AM
  4. Control a reference line in 2 axis.
    Last Post: May 13th, 2011, 09:33 AM
