Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By MPwuzhere
  • 1 Post By BLothian
Thread: Length is determine by angle
    Member mark2009's Avatar
    May 27, 2015
    106
    04:13 AM
    Question Length is determine by angle
    Hey guys,
    Is there a way to determine the length by angle?
    Coeur d Alene, ID
    4,698
    09:13 AM
    Remember when you were in high school and you said you would never use Trigonometry?
    Guess what....it's trigonometry....scroll down a little, you will find a reminder on how it works.
    mark2009 likes this.
    May 27, 2015
    106
    04:13 AM
    Yes a very long time ago.
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    09:13 AM
    You need at least two pieces of information to be able to find the length you are seeking. Having only one angle will not suffice in using trigonometry to find the length.
    May 27, 2015
    106
    04:13 AM
    Yes it's actually two.
    May 27, 2015
    106
    04:13 AM
    my drawing is incorrect
    Member BLothian's Avatar
    December 11, 2013
    Livingston, Scotland
    465
    04:13 PM
    See the attached file, it could probably be simplified but I've had a bit too much Jack Daniels to think that clearly
    Anyway I added some length parameters to keep the segments the same size and it seems to work fine like a bi-fold door but I'm not sure what your purpose for this family is so my example might not suit. There is a formula which calculates the length in question and a reporting parameter for what the actual dimension is when the Angle B is adjusted to prove the formula is correct and hopefully answer your question.
    Attached Files Attached Files
    JBZ
    JBZ is offline
    Senior Member JBZ's Avatar
    December 17, 2010
    Los Angeles
    670
    09:13 AM
    Quote Originally Posted by mark2009 View Post
    Hey guys,
    Back in 2007 I posted a how-to...to create a design assist tool for slanted volumes, etc.
    All one needs to know are any 2 of the 3 pieces of info (rise, run, slope) voila... the math is explained in the posting but based on the parameter names I used these are the formulae:
    Run=Rise/tan(Slope)
    Slope=atan(Rise/Run)
    Slope Percentage=100*tan(Slope)
    With the result being a component that calcs either run, slope or rise, in concert with the rest
    1: Control Parameters: Rise & Slope; Run is derived from them.
    2: Control Parameters:
    Rise & Run; Slope is derived from them.
    3: Control Parameters:
    Slope & Run; Rise is derived from them.
    Fear and Loathing In a CAD vs. BIM World: Slanted Volumes...I guess the Ramp tool isn't enough?
    December 11, 2013
    465
    04:13 PM
    Mark, did bother to look at my family? It does what you are looking for. I've revised it slightly to include a restrictor so that the extreme angles don't break the family. Just change the angle of the parameter Driving_Angle and the Length changes whilst maintaining the length of the panel segments. I'm only on 2015 so I cant see what your family contains.
  1. Limit Pipe length to practical standard length
    By amarkrish108 in forum MEP - General
    Last Post: January 8th, 2014, 02:27 AM
  2. Replies: 0
    Last Post: June 23rd, 2013, 11:45 PM
  3. Replies: 0
    Last Post: May 17th, 2013, 01:45 AM
  4. Replies: 0
    Last Post: December 6th, 2012, 11:45 PM
  5. IFC - how to export length instead of cut length on framing
    By leetkinda in forum Structure - General Questions
    Last Post: August 17th, 2011, 05:38 PM
