Results 1 to 2 of 2
Thread: Revit Rebar Shape Parameters
    December 23, 2015
    1
    12:07 PM
    Hi all,
    First post here. I'm having a problem with 'Revit Rebar Shape Parameters'. I am trying to modify the rebar shapes so that the parameters meet the British Standards 8666:2005. Therefore I need a formula that will mean 'A' will be greater than or equal to '5 * Bar Diameter'. My attempts seem to not work and throw warning messages every time. Any help or advice? Anyone managed to achieve a similar end product?
    (See attached)
    Attached Thumbnails Attached Thumbnails Revit Rebar Shape Parameters-revit-rebar.jpg
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,143
    08:07 AM
    What does A control?
    The easiest method I can think of is to use two parameters - one as a control and one as a calculation.
    A=user input value
    A2=calculation
    Diameter
    if(A<Diameter*5,Diameter*5,A)
    if A is less than D*5 then use D*5 otherwise use A
  1. Rebar Shape Browser
    By Ali Akbar in forum Structure - General Questions
    Last Post: May 15th, 2016, 04:50 PM
  2. rebar shape
    By stefano.88 in forum Structure - General Questions
    Last Post: July 22nd, 2015, 12:55 PM
  3. How to export Rebar shape in Rebar schedule?
    By phamtuan in forum Structure - General Questions
    Last Post: March 18th, 2013, 03:10 PM
  4. S3 Rebar Shape DC
    By gdoherty0102 in forum Architecture - Family Creation
    Last Post: March 30th, 2012, 12:06 PM
  5. Rebar Shape Legend
    By JasonWallis in forum Structure - General Questions
    Last Post: February 17th, 2012, 07:23 AM
