Results 1 to 2 of 2
Thread: Column and Framing Tag label
    November 23, 2015
    1
    03:23 AM
    I need help with column and framing tag. For the plans, I have the type name as label. On the elevations, I need another tag to show just the height. For example in plan the label is W250x33 then in elevation I need it to be just W250. Does anyone know how to do this? Appreciate the help.
    Member byk3bep's Avatar
    January 30, 2014
    449
    04:23 AM
    You will need another tag family, or a different type that references, lets say type comments, then for each family enter the desired type comments and tag the elements.
    You can't have only a part of type name show up (or any other property).
  1. rafter framing in revit wood framing extension
    By Rrbryce in forum Structure - General Questions
    Last Post: October 8th, 2015, 03:59 PM
  2. Revit 2014: Wall join to Column overides column display
    By MrBIMtastic in forum Architecture and General Revit Questions
    Last Post: June 20th, 2015, 12:09 AM
  3. Revit Extensions placing column base connection at top of column
    By wardley31 in forum Architecture and General Revit Questions
    Last Post: December 4th, 2014, 10:29 AM
  4. Yes/No in a Label?
    By DaveP in forum Architecture - Family Creation
    Last Post: September 10th, 2013, 08:43 AM
  5. Replies: 1
    Last Post: May 23rd, 2011, 02:28 PM
