Results 1 to 9 of 9
Like Tree4Likes
  • 2 Post By cellophane
  • 1 Post By cellophane
Thread: need a solution with an angle issue
    Member mark2009's Avatar
    May 27, 2015
    106
    09:38 AM
    Question need a solution with an angle issue
    hey guys,
    I want to start my angle at 90° and finish at 0°, and in between I want to subtract 1.81, so when i set it to 45 degree it will be 43.19.
    any idea how to achieve this?
    cheers.
    May 27, 2015
    106
    09:38 AM
    To clarify on what i mean here is a JPEG.
    Senior Member ekkonap's Avatar
    May 23, 2011
    Netherlands
    582
    11:38 PM
    if(angle<0+x, 0, if(angle>90-x, 90, x))
    May 27, 2015
    106
    09:38 AM
    Thank you Ekkonap. 0-90 degrees works, but in-between theses degrees needs -1.81 so when i change it to 45 it should automatically change to 43.19 or if i change it to 30 degree it be 28.19, but changing it back to 0 or 90 it should not substrate 1.81.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    05:38 PM
    http://www.revitforum.org/tutorials-...day-usage.html
    Use an Or statement and a calculation parameter:
    Using logical OR
    IF ( OR ( x = 1 , y = 2 ) , <true>, <false>)
    Returns <true> if either x=1 or y=2, else <false>
    if(or(Angle=90,Angle=0),Angle,Angle-1.81)
    Attached Thumbnails Attached Thumbnails need a solution with an angle issue-anglecontrol.png
    mark2009 and Gerta75 like this.
    May 27, 2015
    106
    09:38 AM
    Thank you so much Bender. I really really need to get my head around these formulas.
    August 9, 2011
    Louisville, KY
    6,140
    05:38 PM
    Quote Originally Posted by mark2009 View Post
    me too
    7890
    mark2009 likes this.
    May 27, 2015
    106
    09:38 AM
    Morning I have got no Idea if this is possible making the value lie so it says 43.19 but the angle is till 45?
    August 9, 2011
    Louisville, KY
    6,140
    05:38 PM
    The parameter that controls the geometry in the family needs to be the one with the formula. If you look at my example the annotation that constrains the reference line is AngleControl, not Angle
  1. 3D-4D-5D BIM I need the perfect solution!
    By bim3d4d5d in forum Coordination Tools
    Last Post: May 29th, 2014, 10:37 AM
  2. Spiderinnet: Solution or No Solution or Simply a Bug
    By spiderinnet in forum Blog Feeds
    Last Post: March 12th, 2013, 05:15 AM
  3. Worksharing WAN solution
    By ag25 in forum Worksharing, Revit Server & C4R
    Last Post: February 28th, 2013, 06:20 AM
  4. Wrench Solution & Revit...
    By Raigoki in forum Coordination Tools
    Last Post: November 8th, 2012, 01:23 PM
  5. really no solution?
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: March 17th, 2012, 10:39 PM
