Results 1 to 3 of 3
Thread: Creating footing and column families with required rebar
    December 18, 2015
    1
    04:08 AM
    I am trying to create a family for footings, columns, piers, reinforced beams, etc. but I can't save the family with the required rebar in them. Currently I create the footing and label the family per the schedule, place the required rebar then copy and paste the footings and rebar where needed. Is it possible to create a family with the rebar so that when I pull up that particular footing/ column etc type, the rebar is already in place? Also are there any families for PT cables in Revit?
    Mr. Revit OpEd
    2,861
    09:08 PM
    Unless they have quietly made it possible when I wasn't looking...it is not possible to place rebar in a family.
    December 21, 2010
    Phoenix, AZ
    2,556
    09:08 PM
    That seems like an obvious area for improvement. Hopefully this will be in a future update.
  1. rebar cover for structural footing rectangular
    By ob37 in forum Structure - General Questions
    Last Post: March 20th, 2017, 10:36 AM
  2. Rebar Column Problem. Please help
    By fidel91 in forum Structure - General Questions
    Last Post: August 24th, 2015, 10:46 PM
  3. Creating Column Rebar schedule
    By smith125 in forum Structure - General Questions
    Last Post: July 16th, 2015, 06:47 PM
  4. tag for footing, pier and column in one line
    By kev4174 in forum Structure - Family Creation
    Last Post: February 19th, 2014, 08:18 PM
  5. Column & Footing Rebar Graphical Schedules
    By JasonWallis in forum Structure - General Questions
    Last Post: February 15th, 2012, 01:40 AM
