Results 1 to 4 of 4
Thread: Rebar layout face/direction
    November 20, 2015
    3
    05:10 PM
    Hi.
    Is there a way to change the direction of the automatic layout? In my case i want to lay out rebar shape 21 perpendicular to the "normal" layout direction (see attached image)
    Thanks in advance
    Arne
    Attached Thumbnails Attached Thumbnails Rebar layout face/direction-skjermbilde.jpg
    Member byk3bep's Avatar
    January 30, 2014
    449
    06:10 PM
    Here are the controls you need when doing rebar. It does make a difference what shape you are using.
    Make sure you are cutting the element you want to place the rebar in with the view you are working in. In other words make a section through the element or modify the view range in so it cuts the element.
    Rebar layout face/direction-ss1.jpg
    And welcome to the forum.
    November 20, 2015
    3
    05:10 PM
    Thanks for the response. Not shure if I made myself clear, but the problem is not to place the rebar, but to get the automatic layout function to lay the rebar in the desired direction.
    In my attachment the red arrow is the default direction when I use automatic layout (blue circle), like shown. My wish is to lay the rebar in the direction of the green arrow, like drawn (sorry about the bad drawings). Hope you understand my problem.Rebar layout face/direction-forum.jpg
    December 1, 2015
    14
    11:10 AM
    I think the automatic layout will move the rebar shape only in the direction perpendicular to the plane of the shape, to place them in the other direction you would have to do an array. What are you trying to accomplish? That is a wierd arrangement for rebar, do you have an image of what the finished arrangement should look like?
  1. Making rebar grade come before rebar diameter in annotation label
    By einsteino in forum Structure - Family Creation
    Last Post: September 22nd, 2015, 02:12 PM
  2. How to export Rebar shape in Rebar schedule?
    By phamtuan in forum Structure - General Questions
    Last Post: March 18th, 2013, 03:10 PM
  3. Proxy face in Face Based families - delete it?
    By Gordon Price in forum Architecture - Family Creation
    Last Post: February 5th, 2012, 08:07 PM
  4. Wall by face - curved face bug
    By brenehan in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: January 2nd, 2012, 12:56 AM
  5. Control 'Normal Direction' of Mass Face
    By The Dropper in forum Architecture and General Revit Questions
    Last Post: May 18th, 2011, 01:14 PM
