Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By byk3bep
Thread: How to create own family: C channel as column
    March 17, 2015
    10
    01:09 PM
    Dear All,
    I had problem in creating steel C channel as column. I had actually created a c channel as column, but
    I can't place this c channel family into the level which I desired when I placed it, it will always place at 1st storey.
    My C Channel sizes is C30030 in metric size, attach the family which I created. kindly let me know what happen to my family, have I missed any setting.
    Attached Files Attached Files
    Member byk3bep's Avatar
    January 30, 2014
    449
    05:09 AM
    You want to lock the top and bottom of your extrusion to the lower and uppper lever referance planes.
    2 Ways of doing this:
    1. In your family, go to elevation view. Select the extrusion. You will see blue triangles appear (shape handles). Drag them away form their current position and back until the ref plane lights up. Release and a lock key icon should appear. Lock it. Do the same for the other ref. plane.
    2. Activate the align command and lock the bottom and top extrusion ends to the corresponding planes.
    cganiere likes this.
    March 17, 2015
    10
    01:09 PM
    Thanks alot for your advice. I finally make.
    Thanks a lot for your advice. I finally make.
    Quote Originally Posted by byk3bep View Post
  1. Arc Column shape how to create?
    By dedo in forum Structure - General Questions
    Last Post: August 18th, 2016, 06:26 AM
  2. Structural Angle & Channel Column family
    By jean_francois_nant in forum Structure - Family Creation
    Last Post: July 11th, 2014, 03:53 PM
  3. create a tapered steel column
    By pplusd mikef in forum Structure - General Questions
    Last Post: August 2nd, 2013, 07:37 AM
  4. How to create SHS steel column
    By Yan Naing Bo in forum Structure - Family Creation
    Last Post: May 30th, 2012, 03:03 PM
  5. Please kindly check my Lipped-Channel Family
    Last Post: September 2nd, 2011, 02:52 AM
