Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Like Tree2Likes
Thread: How to add a field to the revision schedule in the title block template?
    December 14, 2011
    57
    09:13 PM
    I'm trying to add a letter in front of the revision number ?
    May 14, 2012
    Where the plains meet the mountains
    392
    03:13 PM
    Which version of Revit are you using? With 2016, they introduced "alphanumeric" as one of the options in the revision management dialog.
    December 14, 2011
    57
    09:13 PM
    Quote Originally Posted by CADiva View Post
    I know that you can do that in 2016 obviously I'm using 2014 & 2015
    July 7, 2011
    Rotterdam, Holland
    1,228
    11:13 PM
    You can make your own sequence of characters.
    How to add a field to the revision schedule in the title block template?-sequence-options.jpg
    cganiere likes this.
    December 14, 2011
    57
    09:13 PM
    That doesn't work for multiple sheets with different revisions
    July 7, 2011
    Rotterdam, Holland
    1,228
    11:13 PM
    Sure it does, I do that all the time (see attached images) unless you mean something different.
    How to add a field to the revision schedule in the title block template?-clipboard-1.jpg
    How to add a field to the revision schedule in the title block template?-clipboard-2.jpg
    December 14, 2011
    57
    09:13 PM
    I want revisions P1, P2, C1, C2 for example
    Member TFuller's Avatar
    March 7, 2014
    Evansville, IN
    366
    04:13 PM
    We've hacked it around a bit to do this in 14 and 15 by using the Issued To fields instead.
    July 7, 2011
    Rotterdam, Holland
    1,228
    11:13 PM
    Quote Originally Posted by simon1688 View Post
    aha, don't think that is possible with the standard revision thingy in 2015 unless you use some other parameter as revision, but that would be manual (so a pain in the butt)
    December 14, 2011
    57
    09:13 PM
    Quote Originally Posted by TFuller View Post
    Yes I have done this to but I require one more field in the revisions schedule, how can I add a field to this?
  1. Title Blocks with Assigned Revision Schedule
    By BigIdiot in forum Structure - Family Creation
    Last Post: January 30th, 2015, 10:13 PM
  2. Title Block - Revision Table Text Problem
    By JPREng in forum Architecture and General Revit Questions
    Last Post: December 4th, 2014, 09:44 PM
  3. Replies: 0
    Last Post: February 2nd, 2012, 02:15 PM
  4. Replies: 0
    Last Post: February 1st, 2012, 02:15 AM
  5. Revision block and title block
    By soboyle in forum Architecture and General Revit Questions
    Last Post: April 25th, 2011, 09:22 AM
