Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Like Tree1Likes
Thread: How to create a Family with array of elements with different property values
    September 11, 2015
    4
    04:38 PM
    I need to create a family with varying number of repeating elements (extrusions). The repeating extrusions have properties height, width, thickness and material. I need to set different thickness and material to the repeating extrusions. They will have the same width and height. I could create a family where I arrayed the extrusions but I could not understand how to set up different thickness and material for each array element (extrusion).
    Then I would like to create a Type Catalog so I can import the types from a text file.
    I need to accomplish something like the image below, where I can set the parameters: number of layers, thickness of each layer and material of each layer by a Type Catalog file.
    How to create a Family with array of elements with different property values-screen-shot-2015-09-11-12.35.29-pm.png
    Orlando, FL, USA
    3,088
    12:38 PM
    Welcome to the forum
    It is possible as a family but without the array, but just extrusions put together. The other alternative is to create wall types in a project.
    September 11, 2015
    4
    04:38 PM
    Thank you Alfredo!
    At the beginning I did it without the array. But in that case is it possible to control the number of extrusions added?
    Orlando, FL, USA
    3,088
    12:38 PM
    No. Why don´t you handle this as wall types? This has all the properties of a wall: different layers with different thicknesses and materials.
    September 11, 2015
    4
    04:38 PM
    Alfredo, now I am a bit confused. Let me explain you what is the situation and what is my task.
    Actually I am software developer and not an architect. I have started exploring Revit since last week, because I received the following task:
    I have to create an element in Revit, where I can import the parameters from external database. This element is consisted of variable number of layers with different thicknesses and materials, and same width and height. So I need to import the width, height and the different thicknesses of the layers. So after playing around Revit the last two weeks I come up with solution to create custom Family with extrusions and array them up and to import the parameters with the Type Catalog file generated by the values of the database. However I stuck with the different thickness problem.
    May be I just started wrong and I have to look for another way to go.
    I hope that you can understand my task and goal, despite my bad explanations. I will be ver pleased to give me some suggestion on how to continue here.
    Any help will be appreciated.
    Thank you in advance!
    September 11, 2015
    4
    04:38 PM
    Then is it possible to import the wall properties from a file?
    Sorry for the stupid questions, but I am really a newbie in Revit.
    Member truevis's Avatar
    January 7, 2011
    111
    12:38 PM
    Quote Originally Posted by i_nikolov View Post
    I need to create a family with varying number of repeating elements (extrusions). The repeating extrusions have properties height, width, thickness and material. I need to set different thickness and material to the repeating extrusions...
    I think the primary way to do that is by putting in lots of elements (in a fake array) and having visibility parameters on them.
    10,036
    11:38 AM
    You need to tell us not what the technical problem is you are having (getting hte array to work in Revit) and instead tell us what your task is (what is the THING you are trying to make in Revit?)
    The reason being, i think this is probably something someone is asking you to make, that SHOULD be a system family (as Alfredo Mentioned). If thats the case, it wont pass ANYONES review to make it out of a Revit Family.
    July 7, 2011
    Rotterdam, Holland
    1,169
    06:38 PM
    Arrays are just copies of 1 item, so you can not change the width of those seperatelly.
    Just an idea:
    Make a family with x amount of extrusions (make it more then you will ever need), all locked for height and length to a parameter (which you then fillin with some programming magic you know how to do). For the width of each element add a parameter and name those width01, width02, width03, etc. (or whatever you like). Then again with some programing magic, fill in all those widths with the data from the external file. Then you have to remove the extrusion you don't need. So count the data in your external file and remove the the unneeded extrusions, sure thats possible to program.
    Thats just a brainstorm from me, might not be possible, but IF I knew programming I would try it that way.
    Orlando, FL, USA
    3,088
    12:38 PM
    ...I have to create an element in Revit,...
    And what does that "element" represent? What is it? What category?
  1. Replies: 0
    Last Post: September 8th, 2013, 09:16 AM
  2. Replies: 0
    Last Post: August 13th, 2013, 05:45 AM
  3. Property Line values - Degrees / Minutes / Seconds
    Last Post: April 24th, 2013, 03:27 PM
  4. elements have duplicate 'Mark' / 'Number' values
    By mno in forum Architecture and General Revit Questions
    Last Post: September 13th, 2012, 09:20 AM
  5. How to create Radial array with radius as a parameter
    By tmariappan in forum MEP - General
    Last Post: July 13th, 2011, 12:06 PM
