Results 1 to 5 of 5
Thread: ledger family
    Member trevorpan's Avatar
    February 3, 2014
    Tempe, AZ
    198
    02:20 PM
    ledger family
    Working on a new ledger family, with many types.
    When you start with a structural beam family, there is a reference line called stick symbol and member, and beyond that it says right, or left. Anyone know when to use these, and when not?
    I created a ledger, and it displays short - not the length drawn in plan; so on one side as a test I aligned it with the left. Perhaps I started with the wrong family? Are these planes useful for a different type of member?
    Attached Thumbnails Attached Thumbnails ledger family-member-right.png   ledger family-stick-member.png   ledger family-ledger-perspective.png
    GD_
    GD_ is offline
    December 12, 2013
    32
    05:20 PM
    I think this link will help you:
    BIM & BEAM: Framing template/How to disable auto setback
    Most notably the explanations of how things work/what they do.
    February 3, 2014
    Tempe, AZ
    198
    02:20 PM
    beautiful, thanks GD, I'll review that and post the family. sort of been a start and stop venture getting this family together...
    GD_
    GD_ is offline
    December 12, 2013
    32
    05:20 PM
    No problem! The real important part to solve your problem is that you must lock your beam object extents to the "Member Left/Right" Ref. Planes, as those control the physical element.
    February 3, 2014
    Tempe, AZ
    198
    02:20 PM
    Enclosed is a test model with a few walls.
    The ledger family I've made has a few types and now trims properly with symbolic lines, but does not show up in section or elevation.
    Any ideas?
    Attached Files Attached Files
  1. Ledger display in plan
    By trevorpan in forum Structure - General Questions
    Last Post: September 3rd, 2015, 09:05 PM
  2. Replies: 0
    Last Post: February 4th, 2014, 10:45 PM
  3. Replies: 0
    Last Post: September 27th, 2013, 06:45 AM
  4. Can't change family origin point, family loads into project as hidden lines
    By lukewallace1990 in forum Architecture - Family Creation
    Last Post: February 1st, 2013, 03:51 PM
  5. Replies: 16
    Last Post: April 26th, 2012, 09:16 AM
