Results 1 to 3 of 3
Thread: Help making beam family from profile with multiple types
    October 23, 2014
    19
    10:06 AM
    Hi Guys,
    I am trying to create a new beam family with multiple types. I created a profile and persisted with constraints etc. until I was able to get the family to flex correctly for the several types created.
    Now, when I open up an existing structural framing family and replace the profile with my "new" profile, I don't see how I can enable the user to select any of the profiles I have created. Simply put, I am restricted to only selecting one profile for my new beam family and it looks like I am stuck with that and creating a nice flexible profile was a waste of time.... Am I missing something or have I gone about this the wrong way.
    Profile attached for reference.
    Regards Jake
    Attached Files Attached Files
    10,036
    05:06 AM
    You can't move between different profiles. But if the parameters in the profile are type properties, you can use different profile types in different places. And, you CAN tie the type properties from the profile to parameters in the families themselves.
    October 23, 2014
    19
    10:06 AM
    Hi Aaron,
    Thank you for the reply. My apologies for not responding sooner - I have been out of town for work.
    If I understand correctly, I should try loading the profile then using parameters in the new beam family to adjust the type parameters in the original profile family? I guess I would only need one profile type in the profile family in order to do this, making the other types I created somewhat redundant?
    Many thanks,
    Jake
  1. Aligning multiple applications same .pat file to a .rfa profile
    By Misvit in forum Architecture and General Revit Questions
    Last Post: August 13th, 2015, 01:59 PM
  2. New Sweep Profile for A Beam Family
    By alierrett in forum Structure - General Questions
    Last Post: September 5th, 2014, 10:05 AM
  3. Tags with Multiple Types
    By smurch in forum Architecture - Family Creation
    Last Post: January 28th, 2014, 10:23 PM
  4. Using a profile parameter to define a sweep profile within a family
    By mattsim in forum Architecture - Family Creation
    Last Post: May 16th, 2013, 04:47 AM
  5. Replies: 4
    Last Post: March 14th, 2013, 02:31 AM
