Results 1 to 10 of 10
Thread: Showing miniature rebar shape
    August 25, 2015
    34
    02:41 PM
    Hi there, i was wondering if ts possible to make a thing like shown below (the specific rebar shape and lengths in miniature)
    Atm we are implementing Revit and had a 5-day course (lessons) and even the teacher didnt have a quick solution for this. Any help would be greatly apprechiated!!
    Member Darius's Avatar
    May 6, 2013
    488
    09:41 AM
    for the little miniture symbol not that i know of the little shape i would suggest making in a legend so if you have that symbol in multiple places it can be put on different sheets
    August 25, 2015
    34
    02:41 PM
    All those rebars will be shown in a schedule on the drawing, so the shape and dimensions are known. But as an extra (for ourselves and for the people who actually have to make it) we would like to quickly check the shape and meusurement without having to look it up in the schedule.
    August 25, 2015
    34
    02:41 PM
    sorry for the bump, but i still dont have a solution. Does anyone have any idea if this is even possible with todays software? its a Belgian standard thing.
    Member TRWhitehead's Avatar
    February 16, 2012
    Portland, OR
    328
    06:41 AM
    You could do it as a Generic Annotation with text. Wouldn't directly tie to the rebar but would work. Or you could have tag that has the geometry built but reports those dimensions. You'd have to have a different tag or tag type for each shape.
    Note: with a tag you can't have the dimensions DRIVE the symbolic geometry. It would be nice if you could but unfortunately that isn't possible.
    August 25, 2015
    34
    02:41 PM
    that would be a decent solution indeed, thanx!
    August 25, 2015
    34
    02:41 PM
    Sorry for ther bump, but our office still hasent found a good way to show/fix these miniature rebar-shapes. What we did found is this programm that shows the rebar sghape 1:1 (sofistik)....obviously still not quite what we need. And we found this app from Vietnam: Drag Rebars...that also does look nice. I wondered what all you guys use for this?? Or are we (Belgium) the only ones that use those kinda annotations :P
    Member HansLammerts's Avatar
    April 22, 2011
    472
    01:41 PM
    If you can schedule rebar (codes & ammounts) and get some seperate 3D view from their shapes you can put this on sheets. This seems a logical workflow, isn't this possible Marco?
    Junior Member mfleming's Avatar
    January 31, 2014
    15
    08:41 AM
    Drawing the mini sometimes breaks due to Revit's limitation on line length. If you get to that point you could create the items export the images then insert the images into a Generic Annotation with Label Parameters.
    If you have some API skill, you can extract the images the Shape Library within Revit to incorporate into schedules, tags etc.
    Good luck.
    April 22, 2011
    472
    01:41 PM
    Limitations on oldschool Lines. Can it be more annoying..
  1. Rebar Shape Browser
    By Ali Akbar in forum Structure - General Questions
    Last Post: May 15th, 2016, 04:50 PM
  2. rebar shape
    By stefano.88 in forum Structure - General Questions
    Last Post: July 22nd, 2015, 12:55 PM
  3. How to export Rebar shape in Rebar schedule?
    By phamtuan in forum Structure - General Questions
    Last Post: March 18th, 2013, 03:10 PM
  4. S3 Rebar Shape DC
    By gdoherty0102 in forum Architecture - Family Creation
    Last Post: March 30th, 2012, 12:06 PM
  5. Rebar Shape Legend
    By JasonWallis in forum Structure - General Questions
    Last Post: February 17th, 2012, 07:23 AM
