Results 1 to 3 of 3
Thread: Void not cut in project
    May 14, 2012
    7
    08:40 PM
    I have a problem with my nested void family.
    When I upload family into my project the void family not cut the face (family nested).
    Can someone help?
    Attached the family and images.
    Thanks
    Attached Thumbnails Attached Thumbnails Void not cut in project-problema-2.jpg   Void not cut in project-problema.jpg
    Attached Files Attached Files
    Member byk3bep's Avatar
    January 30, 2014
    449
    09:40 PM
    My numerous atempts at trying to cut an object in the project environment with a void that is part of a nested component have ended in failure. Correct me if I'm wrong, but it looks that this is the case.
    take a look at
    http://www.revitforum.org/structure-...onnection.html
    http://www.revitforum.org/structure-...g-familes.html
    Although it would be nice to have everything modeled in 3D all the time, I have come to appreciate the benefits of 2D components.
    November 18, 2014
    3
    08:40 PM
    Does the highlighted plate need to be it's own family for a reason?
    If it doesn't you can place a void face based family on that extrusion, then create an "unattached" void cut (one that doesn't cut anything) this second void cut is what will be used to cut the beam.
  1. Diameter Dimension of a Void Extrusion within a project
    By floridashaughn in forum Architecture - Family Creation
    Last Post: August 23rd, 2017, 08:30 AM
  2. Void cuts in host family but not when loaded into a project
    By billiam in forum Architecture - Family Creation
    Last Post: March 3rd, 2015, 05:48 PM
  3. Change uncut family void style in project?
    By jmk in forum Architecture and General Revit Questions
    Last Post: May 2nd, 2014, 03:13 PM
  4. Void form not creating void.
    By mikey1073 in forum Architecture - Family Creation
    Last Post: December 6th, 2012, 02:13 PM
  5. Family model with void in the project?
    By como in forum Architecture - Family Creation
    Last Post: October 15th, 2012, 12:37 PM
Tags for this Thread
