Results 1 to 2 of 2
Thread: footing familes
    Member Darius's Avatar
    May 6, 2013
    482
    12:25 PM
    footing familes
    i have made some footing families with base plates i tried to make them fit alot of conditions just wondering what people think of them
    Member byk3bep's Avatar
    January 30, 2014
    449
    05:25 PM
    First of thx for sharing
    Looks ok, but not without room for improvement
    I have an aversion towards families with a "lot" of parameters. Even in my own I get a bit confused at times
    More and more I tend to have just the basic parameters available in the project environment (those that are changed most frequently), the rest of the parameters are available in the family environment for each nested component. So in essence if I want to change a parameter of a bolt > select the footing/component in the project > edit family > select component (bolt) > edit types button, and all parameters concerning that element (and only that element) are available. This saves me the trouble of sifting through other parameters in the project that could (and probably are) of no concern at that particular time.
    Having sad that, I'd like to acknowledge that there was no trouble with figuring out what your parameters are for.
    But still...
    I made a small change to the family, deleted the anchors, nuts, voids, and some parameters that define them. Nested shared component (anchor bolt) allowing the components to be tagged and scheduled, which is a HUGE + !
    Attached Files Attached Files
  1. Adding Labels to Familes
    By nick_h in forum MEP - General
    Last Post: January 23rd, 2014, 07:43 PM
  2. Editing Familes Question
    By Jock in forum Architecture and General Revit Questions
    Last Post: November 6th, 2013, 03:19 PM
  3. Top of Footing
    Last Post: July 20th, 2012, 09:34 AM
  4. Stepped footing not joining with Wall footing
    By AHutchinson in forum Structure - Family Creation
    Last Post: February 14th, 2012, 07:52 PM
  5. recherche de familes de portes
    By ivielor in forum Forum Français
    Last Post: August 12th, 2011, 11:57 AM
