Results 1 to 2 of 2
Thread: Adding parameters to dimensions in Revit
    April 9, 2014
    3
    09:44 AM
    Afternoon,
    This may be a long shot, but has anyone ever had any success with adding parameters to the actual dimensions in Revit?
    I'm wanting to add a parameter to the aligned dimension style but having no such luck in the minute.
    If anyone has any ideas on whether or not this can be done that would be great!
    Cheers
    Mr. Revit OpEd
    2,909
    01:44 AM
    If you are referring to dimensions in a project like we can in the family editor, that can only be done with in-place families. You can apply some parametric logic to a dimension string using the Equality settings. It will allow a dimension to report something like 6 @ 8'-0" = 48'-0" for example.
  1. Base dimensions off of parameters in Revit Families
    By MattKincaid in forum Architecture - Family Creation
    Last Post: January 21st, 2015, 07:37 PM
  2. Adding Multiple Parameters
    By nick_h in forum MEP - General
    Last Post: December 17th, 2014, 11:21 AM
  3. Replies: 0
    Last Post: August 12th, 2014, 02:45 AM
  4. Replies: 0
    Last Post: April 17th, 2012, 11:15 PM
  5. Replies: 0
    Last Post: February 17th, 2012, 02:15 PM
