Results 1 to 4 of 4
Thread: Adaptive Model - automatic pick line by change the parameter
    May 13, 2015
    2
    04:09 AM
    Lightbulb Adaptive Model - automatic pick line by change the parameter
    I have been modelling a Arc steel bridge recently.
    it is a 3 dimension curved arc and I so used the adaptive model and using reference line to create the shape for the model.
    Attained please find my Adaptive family, which include only reference lines, adaptive points and Grid with offset.
    So I load it to a project and pick the steel member to those reference line.
    It is success and do what I want. But there are two following up question about the model.
    1. When I change the parameter (like the offset of grid) the reference line itset will follow the movement and regenerate a curve for me. But when I load into project, the steel member will ignore the change although I pick the length with Lock function.
    2. When I pick two member which is intercross each other, the connection will be automatic set back and I need to adjust the Join Cutback manually, can I turn this function off?
    Thank you
    Attached Files Attached Files
    Orlando, FL, USA
    3,093
    03:09 PM
    I think that "Lock" option is broken, or at least is not supposed to work as you expect in this case (and as I expected when I needed it). Last year, I was modeling the steel structure of a couple of towers during some months, so I made a skeleton of model lines, with the adaptive template, and repeaters, to find the exact location of each member. Then and I inserted the skeleton family of the tower into a project. Then I created structural members by using the pick lines tool, with that "Lock" option activated. The structural members were located exactly where they were supposed to be. Some of them had to be rotated in its cross section, though, but that is understandable. But, the "lock" option did not do anything. For any change in the structure I had to modify the family, reload, and create the steel members again. It was not a big deal to do it again because it was quick, but it would have been better if the "Lock" option could do just that, lock the steel member to the line that we pick.
    Welcome to the forum.
    Member byk3bep's Avatar
    January 30, 2014
    449
    08:09 PM
    I would rly like to take a whack at this, but rvt2014 can't open the file and from the pic cant tell enough.
    So if you cloud put some more pic's along with the parameters you are looking to have control over, it would be a great help
    May 13, 2015
    2
    04:09 AM
    Thank you!
    In case the model include not that much member, it is reasonable to pick the items always.
    But if it changes frequently and contains many memeber, that is a big trouble
  1. Could i change family parameter to shared parameter?
    By dedo in forum Structure - General Questions
    Last Post: August 19th, 2014, 01:11 PM
  2. optional Automatic diagonal line shown on ceiling plans
    By mhug9 in forum Architecture and General Revit Questions
    Last Post: September 5th, 2013, 10:49 AM
  3. Change Tag Geometry/Color with Change to Parameter
    By GMcDowellJr in forum Architecture and General Revit Questions
    Last Post: October 4th, 2012, 07:04 PM
  4. Beam behavior w Pick Line option
    By gaby424 in forum Architecture and General Revit Questions
    Last Post: October 2nd, 2012, 08:04 AM
  5. View template does not seem to pick up settings from linked model
    By Pashcal in forum Architecture and General Revit Questions
    Last Post: May 2nd, 2012, 08:06 PM
Tags for this Thread
