Results 1 to 2 of 2
Thread: Accessing structural material information in a family
    May 8, 2014
    70
    04:21 AM
    Is there a way in which to incorporate the strengths from material in to the related family in order to access them for connection design?
    Accessing structural material information in a family-strengths-revit-material.jpg
    The idea is to be able to use a lookup table in order to calculate the number of bolts required for a simple connection. (Material can not be part of a lookup table? I think it's only dims and number that are accepted?)
    The lookup will be part of the family and operate as (Table, "Shear", Min possible value, Material strength, Bolt size, Web thickness)
    Then in dynamo I will set up a graph to simply state a number of bolts required for each simple end connection and place this information in the model, from calculated shears and tensions.
    I believe this should work reasonably well, again I am open to suggestions/improvements/why don't you just...
    May 8, 2014
    70
    04:21 AM
    I'll assume through lack of response that this is not possible and it will have to be user entry.
    Cheers.
  1. DWF Markup Round Tripping / Accessing DWF while central is accessing file
    By theotheranony in forum Architecture and General Revit Questions
    Last Post: July 23rd, 2014, 02:25 PM
  2. Material Takeoff - Identifying length & width information, query
    By Steveohdearyme in forum Architecture and General Revit Questions
    Last Post: October 27th, 2013, 11:29 PM
  3. Wall Assembly - Structural Material?
    By LKeyser in forum Architecture and General Revit Questions
    Last Post: June 11th, 2012, 07:29 PM
  4. Replies: 0
    Last Post: March 28th, 2012, 04:45 AM
  5. Share information from family with Tag - How?
    By James in forum Architecture - Family Creation
    Last Post: January 19th, 2012, 11:22 PM
