Results 1 to 2 of 2
Thread: Analytical column
    Junior Member sink69's Avatar
    October 19, 2011
    Milan - Italy
    24
    05:19 PM
    Analytical column
    hello guys, I just have one question ....
    Once I created the family of Pillar, from template "Structural Column Metric" how do I change the analytical part of the column with a square section?
    I tried searching on the net but could not find anything ....
    Orlando, FL, USA
    3,087
    12:19 PM
    It´s not clear what exactly you want to achieve. Are you referring to the analytical representation of a structural column in plan view? I don´t think the users have settings to control that, not in the project, and not in the family either. And, if we had the chance to do that, what for?
    If you are referring to the geometric and structural properties of a particular cross section of a column, there are some choices in the "Section shape" parameter of the family, for all the typical steel shapes, which will give you a set of parameters that you can fill in about that particular shape.
  1. Revit 2014: Wall join to Column overides column display
    By MrBIMtastic in forum Architecture and General Revit Questions
    Last Post: June 20th, 2015, 12:09 AM
  2. Revit Extensions placing column base connection at top of column
    By wardley31 in forum Architecture and General Revit Questions
    Last Post: December 4th, 2014, 11:29 AM
  3. Column analytical model
    By Alexander_Odessa in forum Structure - General Questions
    Last Post: November 25th, 2013, 11:17 AM
  4. analytical of beam
    By huyxp in forum Structure - General Questions
    Last Post: July 12th, 2013, 05:44 PM
  5. Analytical model
    By jbenoit44 in forum Structure - General Questions
    Last Post: June 21st, 2012, 03:34 PM
