Results 1 to 2 of 2
Thread: Rebar familyt creation help
    February 16, 2015
    1
    05:32 PM
    Rebar family creation help
    Hi, i'm new to Revit so i am not sure how to solve this problem.
    I am using the "Rebar shape template-EURO"
    I am trying to make a new Rebar family where i can change the lengths of the rebars and then load them into a new project. When i add the labels to the aligned dimensions i can't change the length of the rebars in the family type window.
    The shape status tells me that the "Parameters assigned to the dimensions has no value defined."
    Anyone know how to solved this?
    Thanks!
    Member BD Mackey's Avatar
    November 1, 2013
    466
    10:32 AM
    If you click on the shape status does it give you any warnings? The other thing to consider is those labeled dimension must be selecting the rebar lines, this template is unlike other Revit families, as you draw rebar lines there will be references on the end of those lines, make sure these are what you are dimensioning to. I have seen an additional reference appear if my rebar lines are drawn the same length, try redrawing C at a different length than A
  1. I can't use Rebar, Please help
    By Nsync in forum Structure - General Questions
    Last Post: September 2nd, 2013, 01:30 PM
  2. How to export Rebar shape in Rebar schedule?
    By phamtuan in forum Structure - General Questions
    Last Post: March 18th, 2013, 03:10 PM
  3. Rebar ?'s
    By sachez143 in forum Structure - General Questions
    Last Post: September 7th, 2012, 07:06 PM
  4. REX Rebar
    By gdoherty0102 in forum Structure - General Questions
    Last Post: March 29th, 2011, 11:56 PM
  5. Rebar AGAIN
    Last Post: January 24th, 2011, 01:39 PM
Tags for this Thread
