Results 1 to 2 of 2
Thread: Visibility parameter used for calculation
    February 10, 2015
    1
    10:57 AM
    Lightbulb Visibility parameter used for calculation
    I was wondering if there is a way to use a visibility parameter as a calculation value for another parameter? As in when it is visible it is calculating 1, or if it's off it's 0? any help would be greatly appreciated.
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,415
    10:57 AM
    Yes, if you have a visibility parameter called "Visible" and then have an integer/number type parameter that has a if/than formula:
    Number = if(Visible, 1, 0)
    Edit: You can also incorporate that formula as a part of a length or other parameter type
  1. Giving a Connector a Yes/No visibility Parameter
    By matfloyd2008 in forum MEP - Family Creation
    Last Post: June 5th, 2016, 02:19 AM
  2. Yes/No visibility parameter per view?
    Last Post: January 26th, 2012, 07:56 PM
  3. Yes/No visibility parameter formula problem?
    By milos in forum Architecture - Family Creation
    Last Post: October 6th, 2011, 07:11 AM
  4. If parameter in curtainwal panel area calculation
    By ronvs in forum Architecture - Family Creation
    Last Post: September 7th, 2011, 01:27 PM
  5. Visibility parameter and nested family: bug?
    By jbenoit44 in forum Structure - Family Creation
    Last Post: August 30th, 2011, 03:23 PM
Tags for this Thread
