Results 1 to 3 of 3
Thread: To customize new truss by my self
    Junior Member leeway180's Avatar
    January 23, 2015
    Tokyo, Japan
    36
    08:17 PM
    Hi everyone:
    I would like to customize a big size of truss system length 66000 mm, height 3000 mm to the convention center project. However, when I created truss at truss family and load into revit project surface, the truss became unusual truss, please to refer the attaching Jpeg file. Does anyone know how to customize the thickness or the size of chord and web?
    Sincerely,
    Li-wei
    Attached Thumbnails Attached Thumbnails To customize new truss  by my self-0202truss-question.jpg
    Orlando, FL, USA
    3,096
    07:17 AM
    All you need, in my opinion, is load a Warren truss family in your project. Then, simply specify the structural members that you need for top cord, bottom cord, and diagonals. Make sure that you have the structural framing families already loaded, so that you can assign them to the truss. There is no need to do any work in the family editor. It looks like you worked in the family editor and you created a monster Warren truss made of tiny Warren trusses, which was not the intention. A simple Warren truss with single elements at each member would be enough.
    January 23, 2015
    Tokyo, Japan
    36
    08:17 PM
    Thank you for your advice! I've solved this problem.
    Li-wei
  1. Replies: 0
    Last Post: July 8th, 2013, 11:45 PM
  2. Funky truss
    By sohn in forum Architecture - Family Creation
    Last Post: December 20th, 2012, 07:10 PM
  3. Truss issue
    By sohn in forum Architecture and General Revit Questions
    Last Post: November 26th, 2012, 02:53 PM
  4. Monoslope Truss
    By ITMongoose in forum Structure - Family Creation
    Last Post: February 14th, 2012, 06:58 PM
