Results 1 to 6 of 6
Thread: Creating a solid tapered wall (with the ability to be reinforced) - Help
    January 27, 2015
    8
    04:55 AM
    Hey guys/girls,
    I need to create a tapered structural wall. I did my research and found out how to create the shape using In Place-mass and the structural walls with "create by face". I was able to do this successfully, and the attached pictures show the result.
    The issue I ran into is the following: These are construction drawings, so I need to be able to cut a cross section of this wall and show the reinforcement, which is placed on the outside face and inside face of the wall. So far, when I cut a section, it shows the middle part of the wall as a void, not as solid concrete. Is there a way to model this tapered wall as a fully solid structural wall?
    Also, the wall has a box culvert which crosses through it, so I modeled the void in there already, as seen in the pictures.
    Thank you for the help.
    Alejandro.
    Creating a solid tapered wall (with the ability to be reinforced) - Help-twplan.jpgCreating a solid tapered wall (with the ability to be reinforced) - Help-taperedwall2.jpg
    Orlando, FL, USA
    3,089
    12:55 AM
    Classify your model in place as Structural Foundation, and add a material parameter to the solids. In my opinion, this can be done with simple extrusions. No need to do it as a mass with walls by face. Then, specify "Concrete..." as your material, and then add the rebar.
    Attached Thumbnails Attached Thumbnails Creating a solid tapered wall (with the ability to be reinforced) - Help-2015-01-30_22-17-50.jpg
    January 27, 2015
    8
    04:55 AM
    Alfredo,
    Thank you for the reply. I created the tapered wall as a structural foundation-slab, and it works perfectly since it is a solid wall and I am able to add rebar. Now I am just trying to create the void that goes through that same wall due to the culvert. The tools under structure > opening wont work, since they are meant for walls, roofs, and floors.
    If I understood you correctly, I should be able to change the family type of the inplace mass I modeled (with a void) to structural foundation? Do I do this through "Edit in place", then properties?
    Orlando, FL, USA
    3,089
    12:55 AM
    Edit the existing Model-in Place Structural Foundation Element. Create a Void inside the existing solid. Finish the void, then Finish the Model in Place.
    January 27, 2015
    8
    04:55 AM
    Worked perfectly. Muchas gracias Alfredo!
    Orlando, FL, USA
    3,089
    12:55 AM
    Quote Originally Posted by aalver2 View Post
    ... Muchas gracias Alfredo!
    De nada. Con mucho gusto!
  1. Replies: 0
    Last Post: November 19th, 2014, 11:45 AM
  2. Creating Reinforced Conc Pipe in Revit 2013?
    By doni49 in forum MEP - General
    Last Post: April 25th, 2014, 03:57 PM
  3. Creating Tapered Plate Girder?
    By Vleis in forum Structure - General Questions
    Last Post: April 8th, 2014, 05:13 AM
  4. solid stone wall and coursing
    By deafred in forum Architecture and General Revit Questions
    Last Post: March 20th, 2014, 02:38 PM
  5. Wall types will not display solid fill, strange wall type, and more
    By tweg in forum Architecture and General Revit Questions
    Last Post: December 1st, 2011, 07:56 PM
Tags for this Thread
