Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By TRWhitehead
Thread: Can't see constrains in Family editor.
    December 5, 2014
    12
    12:22 PM
    Experts this is OOTB detail item family, i can't see any dimension constrain in this file but it has constraints and they flex with geometry, so how these constraints are put and how they are working?
    Attached Files Attached Files
    10,199
    07:22 AM
    If I remember correctly, OOTB detail components have the dimensions turned off.
    Go to vg: annotations and turn them back on...
    Member BD Mackey's Avatar
    November 1, 2013
    468
    06:22 AM
    They also have a lot of dimensions as well as reference planes in sketch mode. Sometimes you have to edit the extrusion, filled region etc to see the constraints.
    December 5, 2014
    12
    12:22 PM
    Quote Originally Posted by BD Mackey View Post
    BD Mackey its masking region and even when i go to edit mode i cant see any RP or RL, neither any dimension.
    December 5, 2014
    12
    12:22 PM
    Twiceroadsfool i have checked VG, annotations categories are grayed out and here is print screen of it.
    Attached Thumbnails Attached Thumbnails Can't see constrains in Family editor.-print-screen.png
    Member TRWhitehead's Avatar
    February 16, 2012
    Portland, OR
    328
    05:22 AM
    See the checkbox near the top of that window? That should be turned on. That is why you can't see them
    ponting likes this.
    December 5, 2014
    12
    12:22 PM
    Quote Originally Posted by TRWhitehead View Post
    Wooow...............Thanks TRWhitehead Many thanks
  1. Family Editor changes 2012 - 2014. Constraint to nested family broken.
    By Duncan in forum Architecture - Family Creation
    Last Post: May 4th, 2017, 10:35 PM
  2. Column Family Constrains
    By ahmadmahrous_1 in forum Structure - Family Creation
    Last Post: November 22nd, 2013, 11:33 PM
  3. Replies: 0
    Last Post: April 12th, 2012, 04:15 AM
  4. why what i did in the family editor do not comply with project ?!
    Last Post: October 22nd, 2011, 11:24 PM
