Results 1 to 9 of 9
Thread: spread footing with base plate issue
    Member Darius's Avatar
    May 6, 2013
    482
    12:32 PM
    I have problem with the top of a spread footing not attaching to the bottom of a column I have done a save as on the otb family and added the firm that I work for typical grout and base plate layout and have it fully working with the parameters that I need anchor bolts and all the only problem that I have is that revit sees the top of the anchor bolts as the top of the footing not the base plate any ideas on how to fix this
    Attached Files Attached Files
    November 2, 2012
    13
    07:32 PM
    Hi. You need to select the reference plane at the top of your base plate and check "Is reference" parameter. It should be "Top". Then load you family in project and try to change "Base Offset" parameter of column. I think it should be work properly
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    09:32 AM
    I've never tried adding the base plate to the footing family. It has always been added to the column families as a shared nested component. Anyways, you could try to define the RP that is the top of your place as the Is Reference "Top". I doubt it will work but worth a try.
    Does removing the anchor bolts move the bot of the column to the base place?
    May 6, 2013
    482
    12:32 PM
    with out the anchor bolts it works just fine
    November 2, 2012
    13
    07:32 PM
    It will work fine even with anchors if you change Is Reference to Top
    May 6, 2013
    482
    12:32 PM
    I don't know y I could not get that to work yesterday thanks
    on a side note if u make the anchor bolts separate they can be place in a schedule
    anyway here is the family almost finished cant get the nuts to follow the rest of the anchor bolt thanks for the help
    May 6, 2013
    482
    12:32 PM
    Since this family is posted here I thought I should post it almost completed cant figure out how to get the nuts to move with the rest of the anchor bolts
    December 8, 2010
    Northern California
    3,567
    09:32 AM
    either group them and constrain the group to the reference planes or nest the nut into the family and constrain the reference planes.
    May 6, 2013
    482
    12:32 PM
    finished family for those who want it thanks for the assist in creating this
  1. Project base point issue
    By Dennisodixon in forum Architecture and General Revit Questions
    Last Post: July 5th, 2014, 04:24 AM
  2. Extensions - base plate placed at top of column!
    By sebbbo in forum Structure - General Questions
    Last Post: April 16th, 2014, 09:39 PM
  3. Column Base plate
    By jean_francois_nant in forum Structure - General Questions
    Last Post: December 9th, 2013, 05:12 PM
  4. Elevation not showing properly in my custom base plate tag.
    By cordell in forum Structure - Family Creation
    Last Post: November 19th, 2012, 03:55 PM
  5. Pier and Base Plate Plan details
    By kev4174 in forum Structure - General Questions
    Last Post: January 19th, 2012, 11:29 PM
